We performed cases of wave propagation on a case three-dimensional.
For that, we chose to simulate a copper crystal in CFC configuration with a mesh of size
3 6150 angstroems. For that we use the EAM potential with the file in the DYNAMO format found
here.
The sample is a cube of dimensions 300x600x144 angstroems cube.
The atomic zone is made of 1 024 000 atoms, which forms a cube with side of 300 angstroems.
Two finite elements zones are respectively placed on top
and below the atomic zone (according to the Y axis).
Consequently, boundary conditions are set periodic for zone finite
elements and the atomic zone in the X and Z direction. The meshes used
are both grids with 9 216 elements and 10 625 nodes.
