#include <domain_multiscale.h>
Inheritance diagram for DomainMultiScale:
Public Member Functions | |
| int | build (char *config) |
| This method build a full multiscale domain from a config file. | |
| DomainMultiScale (char *n) | |
| Communicator & | getCommunicator () |
| return the global communicator object | |
| DumperMultiScale & | getDumper () |
| return the global dumper object | |
| double | GetEcin (int domtype, unsigned int id=0) |
| double | GetEcin () |
| virtual function to get kinetik energy | |
| double | GetEpot (int domtype, unsigned int id=0) |
| double | GetEpot () |
| virtual function to get potential energy | |
| double | GetMultiScaleEcin () |
| double | GetMultiScaleEpot () |
| DomainInterface * | model (unsigned int i) |
| return a model from its registering order index | |
| unsigned int | nb_models () |
| return the number of registered models | |
| void | SaveSituation (int i) |
| method that delegate the dump to restart file format to the used codes | |
| void | Update () |
| perform a full step update | |
| void | UpdateForces () |
| compute forces | |
| void | UpdatePositions () |
| update positions | |
| void | UpdateStuck () |
| correction induced by the registered coupling | |
| void | UpdateVelocities () |
| update velocities | |
| virtual | ~DomainMultiScale () |
Private Member Functions | |
| void | build_indexes () |
| generate mapping from models ID to registered order of the models | |
| void | ParseLine (char *line) |
| generic parser method that is called by the parser object on each red line | |
Private Attributes | |
| Communicator * | communicateur |
| global communicator object used to perform all communications | |
| unsigned int | Dim |
| dimension of the multiscale material (should be unified) | |
| std::map< int, int > | dom_group |
| mapping between IDs and communication group IDs | |
| std::vector< int > | dom_indexes |
| mapping between IDs and registered order | |
| std::map< int, DomainInterface * > | dom_tab |
| mapping between IDs and models | |
| DumperMultiScale * | dumper |
| global dumper object used to perform any dump of the multiscale material | |
| StimulationMultiScale * | init_stimulation |
| stimulations of the multiscale material performed before initial step | |
| unsigned int | multi_step |
| notificator of the multitimestep (not used at present time) | |
| char | my_config [256] |
| global config file | |
| StimulationMultiScale * | permanent_stimulation |
| stabilisation of Melh that need to be used at each timestep | |
| std::vector< BridgingInterface * > | rec_tab |
| vector of registered bridged zones | |
Friends | |
| class | Parser |
Definition at line 58 of file domain_multiscale.h.
| DomainMultiScale::DomainMultiScale | ( | char * | n | ) |
Definition at line 74 of file domain_multiscale.cpp.
References dumper, init_stimulation, and multi_step.
00074 : 00075 DomainInterface(n,MULTISCALE,MULTISCALE) 00076 { 00077 dumper = NULL; 00078 init_stimulation = NULL; 00079 multi_step = 1; 00080 }
| DomainMultiScale::~DomainMultiScale | ( | ) | [virtual] |
Definition at line 56 of file domain_multiscale.cpp.
References build_indexes(), communicateur, DBG_INFO, dom_indexes, dom_tab, DUMP, dumper, init_stimulation, nb_models(), permanent_stimulation, and rec_tab.
00056 { 00057 delete dumper; 00058 delete init_stimulation; 00059 delete permanent_stimulation; 00060 00061 for (unsigned int i = 0 ; i < nb_models() ; ++i){ 00062 // here to build the dom_indexes just in case 00063 build_indexes(); 00064 DUMP("deleting domaine (ID=" << dom_indexes[i] << ") " << dom_tab[dom_indexes[i]],DBG_INFO); 00065 delete dom_tab[dom_indexes[i]]; 00066 } 00067 00068 for (unsigned int i = 0 ; i < rec_tab.size() ; ++i) 00069 delete rec_tab[i]; 00070 00071 delete communicateur; 00072 }
Here is the call graph for this function:
| int DomainMultiScale::build | ( | char * | config | ) |
Definition at line 264 of file domain_multiscale.cpp.
References communicateur, Dim, DUMP, dumper, FATAL, DumperMultiScale::Init(), init_stimulation, my_config, StimulationMultiScale::Stimulate(), and Communicator::Synchronize().
Referenced by main().
00264 { 00265 00266 strncpy(my_config,config,255); 00267 00268 if(world_size==1) 00269 communicateur = new UnityMPI(); 00270 // else if (world_size>1){ 00271 // // communicateur = new DistributedMPI(world_size); 00272 // // DOMAINECONTINU = 0; 00273 // // DOMAINEATOMIQUE = 1; 00274 // communicateur = new LinearMPI(); 00275 // DOMAINECONTINU = communicateur->AddGroup(world_size); 00276 // //DOMAINEATOMIQUE = communicateur->AddGroup(world_size-world_size/2); 00277 // // communicateur = new DistributedMPI(world_size); 00278 // } 00279 00280 Parser::ParseConfigFile<DomainMultiScale>(config,"MultiScale",this); 00281 00282 if (!communicateur){FATAL("COM keyword should be used in config file");} 00283 00284 if (dumper) 00285 dumper->Init(); 00286 00287 if (init_stimulation) 00288 init_stimulation->Stimulate(); 00289 00290 communicateur->Synchronize(); 00291 00292 #ifdef USING_EPSN 00293 int epsn_status = 0; 00294 // EPSN Ready 00295 DUMP("EPSN is going to be READY..."); 00296 epsn_status = epsn_itfc->ready(); 00297 if (!epsn_status) { 00298 FATAL("error on EPSN Node ready operation\n"); 00299 } 00300 DUMP("EPSN READY"); 00301 // the main loop 00302 DUMP("EPSN Begin HTG"); 00303 epsn_itfc->beginHTM(); 00304 epsn_itfc->beginLoop("main"); 00305 DUMP("simulation ready to start for EPSN"); 00306 #endif 00307 00308 return Dim; 00309 }
| void DomainMultiScale::build_indexes | ( | ) | [private] |
Definition at line 724 of file domain_multiscale.cpp.
References DBG_INFO, dom_indexes, dom_tab, and DUMP.
Referenced by model(), and ~DomainMultiScale().
00724 { 00725 if (dom_indexes.size()==0){ 00726 /* create index for domains */ 00727 map<int,DomainInterface *>::iterator courant = dom_tab.begin(); 00728 map<int,DomainInterface *>::iterator dernier = dom_tab.end(); 00729 00730 while (courant != dernier){ 00731 DUMP("pushing ID " << (*courant).first,DBG_INFO); 00732 dom_indexes.push_back((*courant).first); 00733 ++courant; 00734 } 00735 } 00736 }
| Communicator& DomainMultiScale::getCommunicator | ( | ) | [inline] |
Definition at line 104 of file domain_multiscale.h.
References communicateur.
00104 { 00105 return *communicateur; 00106 }
| DumperMultiScale& DomainMultiScale::getDumper | ( | ) | [inline] |
| double DomainMultiScale::GetEcin | ( | int | domtype, | |
| unsigned int | id = 0 | |||
Definition at line 94 of file domain_multiscale.cpp.
References DBG_WARNING, and DUMP.
00094 { 00095 // if (domaine_type == DOMAINEATOMIQUE) 00096 // return domA_tab[i]->GetEcin(); 00097 // if (domaine_type == DOMAINECONTINU) 00098 // return domC_tab[i]->GetEcin(); 00099 00100 DUMP("without effect for the moment" << domaine_type << " " << i,DBG_WARNING); 00101 return 0; 00102 }
| double DomainMultiScale::GetEcin | ( | ) | [inline, virtual] |
Implements DomainInterface.
Definition at line 67 of file domain_multiscale.h.
| double DomainMultiScale::GetEpot | ( | int | domtype, | |
Definition at line 116 of file domain_multiscale.cpp.
00116 { 00117 00118 // if (domaine_type == DOMAINEATOMIQUE) 00119 // if (communicateur->amIinGroup(DOMAINEATOMIQUE)){ 00120 // return domA_tab[i]->GetEpot(); 00121 // } 00122 // if (domaine_type == DOMAINECONTINU) 00123 // if (communicateur->amIinGroup(DOMAINECONTINU)){ 00124 // return domC_tab[i]->GetEpot(); 00125 // } 00126 DUMP("without effect for the moment " << domaine_type << " " << i,DBG_WARNING); 00127 return 0; 00128 }
| double DomainMultiScale::GetEpot | ( | ) | [inline, virtual] |
Definition at line 68 of file domain_multiscale.h.
| double DomainMultiScale::GetMultiScaleEcin | ( | ) |
Definition at line 83 of file domain_multiscale.cpp.
00083 { 00084 // if (communicateur->amIinGroup(DOMAINEATOMIQUE)) 00085 // return GetEcin(DOMAINEATOMIQUE); 00086 00087 // if (communicateur->amIinGroup(DOMAINECONTINU)) 00088 // return GetEcin(DOMAINECONTINU); 00089 00090 DUMP("without effect for the moment",DBG_WARNING); 00091 return 0; 00092 }
| double DomainMultiScale::GetMultiScaleEpot | ( | ) |
Definition at line 104 of file domain_multiscale.cpp.
00104 { 00105 // if (communicateur->amIinGroup(DOMAINEATOMIQUE)){ 00106 // return GetEpot(DOMAINEATOMIQUE); 00107 // } 00108 00109 // if (communicateur->amIinGroup(DOMAINECONTINU)){ 00110 // return GetEpot(DOMAINECONTINU); 00111 // } 00112 DUMP("without effect for the moment",DBG_WARNING); 00113 return 0; 00114 }
| DomainInterface* DomainMultiScale::model | ( | unsigned int | i | ) | [inline] |
Definition at line 93 of file domain_multiscale.h.
References build_indexes(), dom_indexes, and dom_tab.
Referenced by DumperMultiScale::CreateDumper(), and StimulationMultiScale::CreateStimulation().
00093 { 00094 build_indexes(); 00095 return dom_tab[dom_indexes[i]]; 00096 };
| unsigned int DomainMultiScale::nb_models | ( | ) | [inline] |
Definition at line 99 of file domain_multiscale.h.
References dom_tab.
Referenced by DumperMultiScale::CreateDumper(), StimulationMultiScale::CreateStimulation(), and ~DomainMultiScale().
00099 { 00100 return dom_tab.size(); 00101 };
| void DomainMultiScale::ParseLine | ( | char * | line | ) | [private] |
Definition at line 311 of file domain_multiscale.cpp.
References _BELYTSCHKO, _BELYTSCHKO_FULL, _DUMMY, _FORMEFAIBLE, _LAMMPS, _LEAST_SQUARE, _LIBMESH, _MD1D, _MYMETHOD, _STAMP, Communicator::AddGroup(), UnitsConverter::AtomsUnits, MaterialContinuumInterface::AutoConfig(), BridgingInterface::build(), DomainContinuumInterface::build(), DomainAtomicInterface::build(), communicateur, UnitsConverter::ComputeEtalon(), DumperMultiScale::CreateDumper(), StimulationMultiScale::CreateStimulation(), DBG_DETAIL, DBG_INFO_STARTUP, DBG_WARNING, DEPGAUSS, DEPUNI, Dim, DISLOEDGE, dom_group, dom_tab, DUMP, dumper, DUMPER1D, DUMPERECIN, DUMPEREPSN, DUMPERFIG, DUMPERLAMMPS, DUMPERPARAVIEW, DUMPERRESTART, DUMPERSCOTCH, DUMPERTEXT, DUMPERVGROUPE, DUMPERXYZ, FATAL, DomainAtomicInterface::Geom(), DumperMultiScale::getDumper(), DomainContinuumInterface::getMaterial(), StimulationMultiScale::GetStimulation(), DomainInterface::ID, IMPULSE, BridgingInterface::Init(), init_stimulation, MATIERELANCEE, MODULATE, my_config, Parser::parse_geometrie(), Parser::parseDouble(), Parser::parseEntier(), Parser::parseMetre(), permanent_stimulation, RAZ, rec_tab, BridgingInterface::SetName(), DumperInterface::SetParam(), StimulationInterface::SetParam(), BridgingInterface::SetParam(), DumperInterface::SetPrefix(), SINUSOIDE, STABILISE, Parser::strNext(), UnitsConverter::unit_code, and VELGAUSS.
00312 { 00313 char mot[256]; 00314 00315 int ID; 00316 line += Parser::strNext(mot,line); 00317 00318 //analyse de la valeur en fonction du switch 00319 if(!strcmp(mot,"MD_CODE")){ 00320 char md_config[255]; 00321 unsigned int md_code=_STAMP; 00322 00323 DUMP("parsing MD_CODE commande = " << line,DBG_INFO_STARTUP); 00324 line+=Parser::strNext(mot,line); 00325 00326 if(!strcmp(mot,"STAMP")) 00327 md_code = _STAMP; 00328 else if(!strcmp(mot,"LAMMPS")) 00329 md_code = _LAMMPS; 00330 else if(!strcmp(mot,"MD1D")) 00331 md_code = _MD1D; 00332 else if(!strcmp(mot,"DUMMY")) 00333 md_code = _DUMMY; 00334 00335 line+=Parser::parseEntier(ID,line); 00336 line+=Parser::strNext(md_config,line); 00337 if (md_config[0] == '\0') 00338 strcpy(md_config,my_config); 00339 00340 if (world_size == 1) 00341 dom_group[ID] = 0; 00342 00343 if (dom_group.count(ID) == 0) 00344 {FATAL("PROCESSOR KEYWORD SHOULD BE USED ON ID " << ID);} 00345 dom_tab[ID] = DomainAtomicInterface::build(md_config,md_code,*communicateur,ID,dom_group[ID]); 00346 if (dom_tab[ID] == NULL) 00347 {FATAL("pas bon");} 00348 00349 DUMP("registered domain (ID=" << ID << ") " << dom_tab[ID],DBG_WARNING); 00350 } 00351 else if(!strcmp(mot,"ELAST_CODE")){ 00352 char elast_config[255]; 00353 unsigned int elast_code; 00354 00355 DUMP("parsing ELAST_CODE commande = " << line,DBG_INFO_STARTUP); 00356 line+=Parser::strNext(mot,line); 00357 00358 if(!strcmp(mot,"LIBMESH")) 00359 elast_code = _LIBMESH; 00360 00361 line+=Parser::parseEntier(ID,line); 00362 line+=Parser::strNext(elast_config,line); 00363 if (elast_config[0] == '\0') 00364 strcpy(elast_config,my_config); 00365 00366 if (world_size == 1) 00367 dom_group[ID] = 0; 00368 00369 if (dom_group.count(ID) == 0) 00370 {FATAL("PROCESSOR KEYWORD SHOULD BE USED ON ID " << ID);} 00371 dom_tab[ID] = DomainContinuumInterface::build(elast_config,Dim,*communicateur,ID,dom_group[ID]); 00372 // dom_ID[nb_materials] = ID; 00373 DUMP("a continu model as been with ID " << ID << " has been created",DBG_WARNING); 00374 } 00375 else if(!strcmp(mot,"BRIDGING_CODE")){ 00376 00377 BridgingInterface * rec; 00378 DomainAtomicInterface * domA; 00379 DomainContinuumInterface * domC; 00380 double param; 00381 00382 int bridging_code=_BELYTSCHKO,IDMD,IDC,geomID; 00383 00384 DUMP("parsing BRIDGING_CODE commande = " << line,DBG_INFO_STARTUP); 00385 line+=Parser::strNext(mot,line); 00386 00387 if(!strcmp(mot,"BELYTSCHKO")) 00388 bridging_code = _BELYTSCHKO; 00389 00390 if(!strcmp(mot,"BELYTSCHKOFULL")) 00391 bridging_code = _BELYTSCHKO_FULL; 00392 00393 if(!strcmp(mot,"FORMEFAIBLE")) 00394 bridging_code = _FORMEFAIBLE; 00395 00396 if(!strcmp(mot,"LEASTSQUARE")) 00397 bridging_code = _LEAST_SQUARE; 00398 00399 if(!strcmp(mot,"MYMETHOD")) 00400 bridging_code = _MYMETHOD; 00401 00402 00403 line+=Parser::parseEntier(IDMD,line); 00404 line+=Parser::parseEntier(IDC,line); 00405 line+=Parser::parseEntier(geomID,line); 00406 00407 00408 00409 00410 domA = static_cast<DomainAtomicInterface *>(dom_tab[IDMD]); 00411 domC = static_cast<DomainContinuumInterface *>(dom_tab[IDC]); 00412 00413 rec = BridgingInterface::build(bridging_code,*domA,*domC,geomID,Dim,*communicateur); 00414 00415 int lu = Parser::strNext(mot,line); 00416 00417 while (lu){ 00418 line += lu; 00419 line+=Parser::parseDouble(param,line); 00420 DUMP("parsing key " << mot << " value = " << param << " nb de rec = " << rec_tab.size(),DBG_WARNING); 00421 rec->SetParam(mot,param); 00422 lu = Parser::strNext(mot,line); 00423 DUMP("lu = " << lu,DBG_DETAIL); 00424 } 00425 00426 char recname[256]; 00427 sprintf(recname,"bridge-%d",(int)rec_tab.size()); 00428 rec->SetName(recname); 00429 00430 rec->Init(); 00431 rec_tab.push_back(rec); 00432 // ++nb_recouvrement; 00433 00434 } 00435 else if(!strcmp(mot,"AUTOCONFIG")){ 00436 double tmesh; 00437 double padSize; 00438 int IDMD,IDC; 00439 DomainContinuumInterface * domC; 00440 DomainAtomicInterface * domA; 00441 00442 DUMP("parsing AUTOCONFIG commande = " << line,DBG_INFO_STARTUP); 00443 00444 line+=Parser::parseEntier(IDMD,line); 00445 line+=Parser::parseEntier(IDC,line); 00446 00447 line+=Parser::parseMetre(tmesh,line); 00448 line+=Parser::parseMetre(padSize,line); 00449 00450 domC = static_cast<DomainContinuumInterface *>(dom_tab[IDC]); 00451 domA = static_cast<DomainAtomicInterface *>(dom_tab[IDMD]); 00452 00453 domC->getMaterial().AutoConfig(domA->Geom(),tmesh,padSize); 00454 } 00455 else if(!strcmp(mot,"DIMENSION")){ 00456 line+=Parser::parseEntier((int &)Dim,line); 00457 DUMP("parsing DIMENSION commande = " << Dim,DBG_INFO_STARTUP); 00458 dumper = new DumperMultiScale(*this,Dim); 00459 init_stimulation = new StimulationMultiScale(*this,Dim); 00460 permanent_stimulation = new StimulationMultiScale(*this,Dim); 00461 } 00462 else if(!strcmp(mot,"STIMULATION")){ 00463 line+=Parser::strNext(mot,line); 00464 00465 if(!strcmp(mot,"GAUSS")){ 00466 DUMP("parsing STIMULATION commande = " << line,DBG_INFO_STARTUP); 00467 double LWave,Intensity; 00468 line+=Parser::parseMetre(LWave,line); 00469 line+=Parser::parseMetre(Intensity,line); 00470 int bID = Parser::parse_geometrie(line); 00471 if (bID == -1){FATAL("Geometrie could not be parsed for keyword STIMULATIONGAUSS");} 00472 if (!init_stimulation){FATAL("DIMENSION KEYWORD SHOULD BE USED BEFORE IN CONFIG FILE");} 00473 std::vector<int> stim_indexes = init_stimulation->CreateStimulation(DEPGAUSS,Intensity,bID); 00474 for (unsigned k = 0 ; k < stim_indexes.size() ; ++k) 00475 init_stimulation->GetStimulation(stim_indexes[k])->SetParam("LWave",LWave); 00476 00477 int lu = Parser::strNext(mot,line); 00478 double param; 00479 if (lu>0) 00480 if (!strcmp(mot,"Direction")){ 00481 line += lu; 00482 line+=Parser::parseDouble(param,line); 00483 stim_indexes = init_stimulation->CreateStimulation(VELGAUSS,Intensity,bID); 00484 for (unsigned k = 0 ; k < stim_indexes.size() ; ++k){ 00485 init_stimulation->GetStimulation(stim_indexes[k])->SetParam("LWave",LWave); 00486 init_stimulation->GetStimulation(stim_indexes[k])->SetParam("Direction",param); 00487 } 00488 } 00489 } 00490 else if(!strcmp(mot,"IMPULSE")){ 00491 double direction; 00492 DUMP("parsing STIMULATION commande = " << line,DBG_INFO_STARTUP); 00493 double LWave,Intensity; 00494 line+=Parser::parseMetre(LWave,line); 00495 line+=Parser::parseMetre(Intensity,line); 00496 line+=Parser::parseDouble(direction,line); 00497 int bID = Parser::parse_geometrie(line); 00498 if (bID == -1){FATAL("Geometrie could not be parsed for keyword STIMULATIONGAUSS");} 00499 if (!init_stimulation){FATAL("DIMENSION KEYWORD SHOULD BE USED BEFORE IN CONFIG FILE");} 00500 std::vector<int> stim_indexes = init_stimulation->CreateStimulation(IMPULSE,Intensity,bID); 00501 for (unsigned k = 0 ; k < stim_indexes.size() ; ++k){ 00502 init_stimulation->GetStimulation(stim_indexes[k])->SetParam("LWave",LWave); 00503 init_stimulation->GetStimulation(stim_indexes[k])->SetParam("Direction",direction); 00504 } 00505 } 00506 else if(!strcmp(mot,"DISLOEDGE")){ 00507 double direction; 00508 DUMP("parsing STIMULATION commande = " << line,DBG_INFO_STARTUP); 00509 double burgers,posx,posy,epsilonxy,width=0; 00510 line+=Parser::parseMetre(burgers,line); 00511 line+=Parser::parseMetre(width,line); 00512 line+=Parser::parseMetre(posx,line); 00513 line+=Parser::parseMetre(posy,line); 00514 line+=Parser::parseDouble(epsilonxy,line); 00515 int bID = Parser::parse_geometrie(line); 00516 if (bID == -1){FATAL("Geometrie could not be parsed for keyword STIMULATIONGAUSS");} 00517 if (!init_stimulation){FATAL("DIMENSION KEYWORD SHOULD BE USED BEFORE IN CONFIG FILE");} 00518 std::vector<int> stim_indexes = init_stimulation->CreateStimulation(DISLOEDGE,width,bID); 00519 for (unsigned k = 0 ; k < stim_indexes.size() ; ++k){ 00520 init_stimulation->GetStimulation(stim_indexes[k])->SetParam("BURGERS",burgers); 00521 init_stimulation->GetStimulation(stim_indexes[k])->SetParam("POSX",posx); 00522 init_stimulation->GetStimulation(stim_indexes[k])->SetParam("POSY",posy); 00523 init_stimulation->GetStimulation(stim_indexes[k])->SetParam("EPSILONXY",epsilonxy); 00524 } 00525 } 00526 00527 00528 if(!strcmp(mot,"MODULATE")){ 00529 DUMP("parsing STIMULATION commande = " << line,DBG_INFO_STARTUP); 00530 double LWave,Intensity; 00531 line+=Parser::parseMetre(LWave,line); 00532 line+=Parser::parseDouble(Intensity,line); 00533 int bID = Parser::parse_geometrie(line); 00534 if (!init_stimulation){FATAL("DIMENSION KEYWORD SHOULD BE USED BEFORE IN CONFIG FILE");} 00535 std::vector<int> stim_indexes = init_stimulation->CreateStimulation(MODULATE,Intensity,bID); 00536 for (unsigned k = 0 ; k < stim_indexes.size() ; ++k) 00537 init_stimulation->GetStimulation(stim_indexes[k])->SetParam("LWave",LWave); 00538 } 00539 if(!strcmp(mot,"UNI")){ 00540 DUMP("parsing STIMULATION commande = " << line,DBG_INFO_STARTUP); 00541 double Intensity; 00542 line+=Parser::parseMetre(Intensity,line); 00543 00544 int bID = Parser::parse_geometrie(line); 00545 if (bID == -1){FATAL("Geometrie could not be parsed for keyword STIMULATIONGAUSS");} 00546 if (!init_stimulation){FATAL("DIMENSION KEYWORD SHOULD BE USED BEFORE IN CONFIG FILE");} 00547 std::vector<int> stim_indexes = init_stimulation->CreateStimulation(DEPUNI,Intensity,bID); 00548 00549 double param; 00550 00551 int lu = Parser::strNext(mot,line); 00552 while (lu){ 00553 line += lu; 00554 line+=Parser::parseDouble(param,line); 00555 DUMP("parsing key " << mot << " value = " << param,DBG_INFO_STARTUP); 00556 for (unsigned k = 0 ; k < stim_indexes.size() ; ++k) 00557 init_stimulation->GetStimulation(stim_indexes[k])->SetParam(mot,param); 00558 lu = Parser::strNext(mot,line); 00559 DUMP("lu = " << lu,DBG_INFO_STARTUP); 00560 } 00561 } 00562 else if(!strcmp(mot,"SIN")){ 00563 DUMP("parsing STIMULATION commande = " << line,DBG_INFO_STARTUP); 00564 double LWave,Intensity; 00565 line+=Parser::parseMetre(LWave,line); 00566 line+=Parser::parseMetre(Intensity,line); 00567 int bID = Parser::parse_geometrie(line); 00568 if (!init_stimulation){FATAL("DIMENSION KEYWORD SHOULD BE USED BEFORE IN CONFIG FILE");} 00569 std::vector<int> stim_indexes = init_stimulation->CreateStimulation(SINUSOIDE,Intensity,bID); 00570 for (unsigned k = 0 ; k < stim_indexes.size() ; ++k) 00571 init_stimulation->GetStimulation(stim_indexes[k])->SetParam("LWave",LWave); 00572 } 00573 else if(!strcmp(mot,"RAZ")){ 00574 DUMP("parsing STIMULATION commande = " << mot << " " << line,DBG_INFO_STARTUP); 00575 int bID = Parser::parse_geometrie(line); 00576 if (!init_stimulation){FATAL("DIMENSION KEYWORD SHOULD BE USED BEFORE IN CONFIG FILE");} 00577 int lu = Parser::strNext(mot,line); 00578 int freq = 1; 00579 if (lu && strcmp(mot,"FREQ")==0) { 00580 line += lu; 00581 line += Parser::parseEntier(freq,line); 00582 DUMP("parsing FREQ commande " << freq,DBG_INFO_STARTUP); 00583 } 00584 permanent_stimulation->CreateStimulation(RAZ,0,bID,freq); 00585 } 00586 else if(!strcmp(mot,"MATIERELANCEE")){ 00587 DUMP("parsing STIMULATION commande = " << mot << " " << line,DBG_INFO_STARTUP); 00588 double intensity; 00589 double Axe; 00590 line += Parser::parseDouble(Axe,line); 00591 line += Parser::parseDouble(intensity,line); 00592 int bID = Parser::parse_geometrie(line); 00593 if (bID == -1){FATAL("je n'ai pas pu parser la geometrie pour matiere lancee !!");} 00594 if (!init_stimulation){FATAL("DIMENSION KEYWORD SHOULD BE USED BEFORE IN CONFIG FILE");} 00595 std::vector<int> stim_indexes = init_stimulation->CreateStimulation(MATIERELANCEE,intensity,bID); 00596 for (unsigned k = 0 ; k < stim_indexes.size() ; ++k) 00597 init_stimulation->GetStimulation(stim_indexes[k])->SetParam("Axe",Axe); 00598 } 00599 else if(!strcmp(mot,"STABILISE")){ 00600 DUMP("parsing STIMULATION commande = " << mot,DBG_INFO_STARTUP); 00601 int lu = Parser::strNext(mot,line); 00602 int freq = 1; 00603 if (lu && strcmp(mot,"FREQ")==0) { 00604 line += lu; 00605 line += Parser::parseEntier(freq,line); 00606 } 00607 00608 00609 permanent_stimulation->CreateStimulation(STABILISE,0,-1,freq); 00610 } 00611 else if(!strcmp(mot,"DISLOEDGEBORDERS")){ 00612 double direction; 00613 DUMP("parsing STIMULATION commande = " << line,DBG_INFO_STARTUP); 00614 double burgers,posx,posy,epsilonxy,width=0; 00615 line+=Parser::parseMetre(burgers,line); 00616 line+=Parser::parseMetre(width,line); 00617 line+=Parser::parseMetre(posx,line); 00618 line+=Parser::parseMetre(posy,line); 00619 line+=Parser::parseDouble(epsilonxy,line); 00620 int bID = Parser::parse_geometrie(line); 00621 if (bID == -1){FATAL("Geometrie could not be parsed for keyword STIMULATIONGAUSS");} 00622 if (!permanent_stimulation){FATAL("DIMENSION KEYWORD SHOULD BE USED BEFORE IN CONFIG FILE");} 00623 std::vector<int> stim_indexes = permanent_stimulation->CreateStimulation(DISLOEDGE,width,bID); 00624 for (unsigned k = 0 ; k < stim_indexes.size() ; ++k){ 00625 permanent_stimulation->GetStimulation(stim_indexes[k])->SetParam("BURGERS",burgers); 00626 permanent_stimulation->GetStimulation(stim_indexes[k])->SetParam("POSX",posx); 00627 permanent_stimulation->GetStimulation(stim_indexes[k])->SetParam("POSY",posy); 00628 permanent_stimulation->GetStimulation(stim_indexes[k])->SetParam("EPSILONXY",epsilonxy); 00629 } 00630 } 00631 } 00632 else if(!strcmp(mot,"UNITCODE")){ 00633 DUMP("parsing UNITCODE commande = " << line,DBG_INFO_STARTUP); 00634 line+=Parser::strNext(mot,line); 00635 if (!strcmp(mot,"AtomsUnits")) 00636 UnitsConverter::unit_code = UnitsConverter::AtomsUnits; 00637 00638 UnitsConverter::ComputeEtalon(); 00639 } 00640 else if(!strcmp(mot,"PROCESSORS")){ 00641 line+=Parser::strNext(mot,line); 00642 int id = atoi(mot); 00643 DUMP("id = " << id,DBG_INFO_STARTUP); 00644 line+=Parser::strNext(mot,line); 00645 int nb_procs = atoi(mot); 00646 DUMP("nb_procs = " << nb_procs,DBG_INFO_STARTUP); 00647 dom_group[id] = communicateur->AddGroup(nb_procs); 00648 DUMP("model ID " << id << " got communication group " << dom_group[id],DBG_INFO_STARTUP); 00649 } 00650 else if(!strcmp(mot,"COM")){ 00651 if (world_size==1)return; 00652 line+=Parser::strNext(mot,line); 00653 if (!strcmp(mot,"DISTRIBUTED")){ 00654 communicateur = new LinearMPI(); 00655 } 00656 } 00657 else if(!strcmp(mot,"DUMPER")){ 00658 char freq[255]; 00659 00660 std::vector<int> dump_indexes; 00661 00662 DUMP("parsing DUMPER commande = " << line,DBG_INFO_STARTUP); 00663 line+=Parser::strNext(mot,line); 00664 line+=Parser::strNext(freq,line); 00665 int frequency = atoi(freq); 00666 DUMP("frequency injected = " << frequency,DBG_INFO_STARTUP); 00667 if (!dumper){FATAL("DIMENSION KEYWORD SHOULD BE USED BEFORE IN CONFIG FILE");} 00668 if (!strcmp(mot,"PARAVIEW")) 00669 dump_indexes = dumper->CreateDumper(DUMPERPARAVIEW,frequency); 00670 else if (!strcmp(mot,"TEXT")) 00671 dump_indexes = dumper->CreateDumper(DUMPERTEXT,frequency); 00672 else if (!strcmp(mot,"DUMPER1D")) 00673 dump_indexes = dumper->CreateDumper(DUMPER1D,frequency); 00674 else if (!strcmp(mot,"DUMPERVGROUPE")) 00675 dump_indexes = dumper->CreateDumper(DUMPERVGROUPE,frequency); 00676 else if (!strcmp(mot,"DUMPERECIN")) 00677 dump_indexes = dumper->CreateDumper(DUMPERECIN,frequency); 00678 else if (!strcmp(mot,"SCOTCH")) 00679 dump_indexes = dumper->CreateDumper(DUMPERSCOTCH,frequency); 00680 #ifdef USING_FIG 00681 else if (!strcmp(mot,"FIG")) 00682 dump_indexes = dumper->CreateDumper(DUMPERFIG,frequency); 00683 #endif 00684 else if (!strcmp(mot,"LAMMPS")) 00685 dump_indexes = dumper->CreateDumper(DUMPERLAMMPS,frequency); 00686 else if (!strcmp(mot,"XYZ")) 00687 dump_indexes = dumper->CreateDumper(DUMPERXYZ,frequency); 00688 #ifdef USING_EPSN 00689 else if (!strcmp(mot,"EPSN")){ 00690 line+=Parser::strNext(mot,line); 00691 dump_indexes = dumper->CreateDumper(DUMPEREPSN,frequency); 00692 strncpy(xmlepsnfile,mot,255); 00693 } 00694 #endif //USING_EPSN 00695 else if (!strcmp(mot,"RESTART")){ 00696 dump_indexes = dumper->CreateDumper(DUMPERRESTART,frequency); 00697 } 00698 else{FATAL("Unknown dumper : " << mot);} 00699 DUMP("dumpers instanciated ... ",DBG_INFO_STARTUP); 00700 while (strlen(mot)>0){ 00701 double value = 1; 00702 00703 line+=Parser::strNext(mot,line); 00704 if(!strcmp(mot,"FILTERDISP") || !strcmp(mot,"FILTERGEOM") 00705 || !strcmp(mot,"FILTERFORCE") || !strcmp(mot,"FILTERVEL")){ 00706 line+=Parser::parseDouble(value,line); 00707 } 00708 if(!strcmp(mot,"PREFIX")){ 00709 char prefix[500]; 00710 line+=Parser::strNext(prefix,line); 00711 for (unsigned k = 0 ; k < dump_indexes.size() ; ++k) 00712 dumper->getDumper(dump_indexes[k])->SetPrefix(prefix); 00713 continue; 00714 } 00715 for (unsigned k = 0 ; k < dump_indexes.size() ; ++k) 00716 dumper->getDumper(dump_indexes[k])->SetParam(mot,value); 00717 } 00718 DUMP("dumpers configured ... ",DBG_INFO_STARTUP); 00719 } 00720 00721 00722 }
| void DomainMultiScale::SaveSituation | ( | int | i | ) | [virtual] |
Definition at line 130 of file domain_multiscale.cpp.
References Communicator::amIinGroup(), communicateur, dom_group, dom_tab, STARTTIMER, and STOPTIMER.
00130 { 00131 00132 map<int,DomainInterface *>::iterator courant = dom_tab.begin(); 00133 map<int,DomainInterface *>::iterator dernier = dom_tab.end(); 00134 00135 STARTTIMER("Saving Situation"); 00136 while (courant != dernier){ 00137 if (communicateur->amIinGroup(dom_group[(*courant).first])) 00138 (*courant).second->SaveSituation(index); 00139 } 00140 STOPTIMER("Saving Situation"); 00141 00142 }
| void DomainMultiScale::Update | ( | ) |
a full explicit step is normally composed of a position update, a force computation, a velocity update, and an eventual coupling correction
Definition at line 145 of file domain_multiscale.cpp.
References Communicator::amIinGroup(), communicateur, dom_group, dom_tab, rec_tab, STARTTIMER, and STOPTIMER.
00145 { 00146 00147 map<int,DomainInterface *>::iterator courant = dom_tab.begin(); 00148 map<int,DomainInterface *>::iterator dernier = dom_tab.end(); 00149 00150 STARTTIMER("FullStep"); 00151 while (courant != dernier){ 00152 if (communicateur->amIinGroup(dom_group[(*courant).first])) 00153 { 00154 00155 (*courant).second->UpdatePositions(); 00156 (*courant).second->UpdateForces(); 00157 (*courant).second->UpdateVelocities(); 00158 } 00159 ++courant; 00160 } 00161 00162 for (unsigned int i = 0 ; i < rec_tab.size() ; ++i) 00163 rec_tab[i]->Stucking(); 00164 00165 STOPTIMER("FullStep"); 00166 }
| void DomainMultiScale::UpdateForces | ( | ) | [virtual] |
compute forces
Definition at line 221 of file domain_multiscale.cpp.
References Communicator::amIinGroup(), communicateur, dom_group, dom_tab, permanent_stimulation, STARTTIMER, StimulationMultiScale::Stimulate(), and STOPTIMER.
00221 { 00222 #ifdef USING_EPSN 00223 if (epsn_itfc->isNodeInitialized()) 00224 epsn_itfc->beginTask("updateforces"); 00225 #endif 00226 00227 map<int,DomainInterface *>::iterator courant = dom_tab.begin(); 00228 map<int,DomainInterface *>::iterator dernier = dom_tab.end(); 00229 00230 00231 STARTTIMER("StepForces"); 00232 while (courant != dernier){ 00233 if (communicateur->amIinGroup(dom_group[(*courant).first])) 00234 (*courant).second->UpdateForces(); 00235 ++courant; 00236 } 00237 STOPTIMER("StepForces"); 00238 00239 STARTTIMER("StabiliseStimulations"); 00240 permanent_stimulation->Stimulate(); 00241 STOPTIMER("StabiliseStimulations"); 00242 00243 #ifdef USING_EPSN 00244 if (epsn_itfc->isNodeInitialized()) 00245 epsn_itfc->endTask("updateforces"); 00246 #endif 00247 }
| void DomainMultiScale::UpdatePositions | ( | ) | [virtual] |
update positions
Definition at line 169 of file domain_multiscale.cpp.
00169 { 00170 #ifdef USING_EPSN 00171 if (epsn_itfc->isNodeInitialized()) 00172 epsn_itfc->beginTask("updatepositions"); 00173 #endif 00174 00175 map<int,DomainInterface *>::iterator courant = dom_tab.begin(); 00176 map<int,DomainInterface *>::iterator dernier = dom_tab.end(); 00177 00178 STARTTIMER("StepPositions"); 00179 while (courant != dernier){ 00180 if (communicateur->amIinGroup(dom_group[(*courant).first])){ 00181 (*courant).second->UpdatePositions(); 00182 } 00183 00184 ++courant; 00185 } 00186 STOPTIMER("StepPositions"); 00187 00188 #ifdef USING_EPSN 00189 if (epsn_itfc->isNodeInitialized()) 00190 epsn_itfc->endTask("updatepositions"); 00191 #endif 00192 00193 }
| void DomainMultiScale::UpdateStuck | ( | ) |
Definition at line 249 of file domain_multiscale.cpp.
References rec_tab.
00249 { 00250 #ifdef USING_EPSN 00251 if (epsn_itfc->isNodeInitialized()) 00252 epsn_itfc->beginTask("updatecoupling"); 00253 #endif 00254 00255 for (unsigned int i=0; i < rec_tab.size(); ++i) 00256 rec_tab[i]->Stucking(); 00257 00258 #ifdef USING_EPSN 00259 if (epsn_itfc->isNodeInitialized()) 00260 epsn_itfc->endTask("updatecoupling"); 00261 #endif 00262 }
| void DomainMultiScale::UpdateVelocities | ( | ) | [virtual] |
update velocities
Definition at line 196 of file domain_multiscale.cpp.
00196 { 00197 #ifdef USING_EPSN 00198 if (epsn_itfc->isNodeInitialized()) 00199 epsn_itfc->beginTask("updatevelocities"); 00200 #endif 00201 00202 map<int,DomainInterface *>::iterator courant = dom_tab.begin(); 00203 map<int,DomainInterface *>::iterator dernier = dom_tab.end(); 00204 00205 STARTTIMER("StepVelocities"); 00206 while (courant != dernier){ 00207 if (communicateur->amIinGroup(dom_group[(*courant).first])) 00208 (*courant).second->UpdateVelocities(); 00209 ++courant; 00210 } 00211 STOPTIMER("StepVelocities"); 00212 00213 #ifdef USING_EPSN 00214 if (epsn_itfc->isNodeInitialized()) 00215 epsn_itfc->endTask("updatevelocities"); 00216 #endif 00217 00218 }
friend class Parser [friend] |
Definition at line 119 of file domain_multiscale.h.
Communicator* DomainMultiScale::communicateur [private] |
Definition at line 145 of file domain_multiscale.h.
Referenced by build(), getCommunicator(), ParseLine(), SaveSituation(), Update(), UpdateForces(), UpdatePositions(), UpdateVelocities(), and ~DomainMultiScale().
unsigned int DomainMultiScale::Dim [private] |
Definition at line 139 of file domain_multiscale.h.
Referenced by build(), and ParseLine().
std::map<int,int> DomainMultiScale::dom_group [private] |
Definition at line 129 of file domain_multiscale.h.
Referenced by ParseLine(), SaveSituation(), Update(), UpdateForces(), UpdatePositions(), and UpdateVelocities().
std::vector<int> DomainMultiScale::dom_indexes [private] |
Definition at line 132 of file domain_multiscale.h.
Referenced by build_indexes(), model(), and ~DomainMultiScale().
std::map<int, DomainInterface *> DomainMultiScale::dom_tab [private] |
Definition at line 127 of file domain_multiscale.h.
Referenced by build_indexes(), model(), nb_models(), ParseLine(), SaveSituation(), Update(), UpdateForces(), UpdatePositions(), UpdateVelocities(), and ~DomainMultiScale().
DumperMultiScale* DomainMultiScale::dumper [private] |
Definition at line 148 of file domain_multiscale.h.
Referenced by build(), DomainMultiScale(), getDumper(), ParseLine(), and ~DomainMultiScale().
Definition at line 150 of file domain_multiscale.h.
Referenced by build(), DomainMultiScale(), ParseLine(), and ~DomainMultiScale().
unsigned int DomainMultiScale::multi_step [private] |
Definition at line 137 of file domain_multiscale.h.
Referenced by DomainMultiScale().
char DomainMultiScale::my_config[256] [private] |
global config file
Definition at line 142 of file domain_multiscale.h.
Definition at line 152 of file domain_multiscale.h.
Referenced by ParseLine(), UpdateForces(), and ~DomainMultiScale().
std::vector<BridgingInterface *> DomainMultiScale::rec_tab [private] |
Definition at line 134 of file domain_multiscale.h.
Referenced by ParseLine(), Update(), UpdateStuck(), and ~DomainMultiScale().
1.5.2
