ReferenceManager< Ref > Class Template Reference
#include <reference_manager.h>
Inheritance diagram for ReferenceManager< Ref >:
Inheritance graph
[legend]
List of all members.
Public Member Functions
void AttachDuoDistributedVector (void *v, ContenerTableauRefAtome< Ref > *c)
 request attaching a given duodistributed vecotr with a given contener c
void AttachVector (double *v, ContenerTableauRefAtome< Ref > *c)
 request attaching a given vector v with a given contener c
 ReferenceManager (MPI_Comm c)
ContenerTableauRefAtome< Ref > & RequestCreationSubSet (char *name)
 the contener of subsets of atoms may only be created through refmanager
void UpdateRefSubSets ()
 function that start the updating process of all attached structures
virtual ~ReferenceManager ()
Protected Member Functions
void AdjustSizeRecvBuffers (std::map< int, std::vector< double > > &recv_buffer, std::map< int, std::vector< int > > &recv_buffer2)
 in exchanging attached values this function set correct size to buffers
void AnalyseSubSets ()
 analyse the sent atoms to compute the mask needed to exchange attached values
void BuildSendingBuffers (std::map< int, std::vector< double > > &send_buffer, std::map< int, std::vector< int > > &send_buffer2)
 in exchanging attached values this function build sending buffers
void CheckSubSetsCardinal ()
 check the saved cardinals of the subsets
void ClearSTL ()
 clear all internal structures (based on STL)
void CreationExchangedAtomsInSubSets ()
 create in the subsets the atoms locally created by migration process
void DecodeBuffers (std::map< int, std::vector< double > > &recv_buffer, std::map< int, std::vector< int > > &recv_buffer2)
 in exchanging attached values this function decode the sended buffers
void ExchangeSubSetAttachedValues ()
 perform real value exchange communication
void ExchangeSubSetsMasks ()
 perform the exchange to let know the ownership mask of migrated atoms
void PrintBilanToScreen ()
 print bilan for concerned conteneur : used only to debug
Protected Attributes
void * > >
attached_duo
 attached duos that need to be updated as well as the conteners
std::map< Ref, std::map< int,
std::vector< double > >,
typename Ref::RefComparator >
attached_values
 attached values (we won't send complete vector)
std::vector< int > >, typename
attached_values_duo
 attached values in the duodistributed vector
double * > >
attached_vectors
 attached vectors that need to be updated as well as the conteners
std::map< Ref, int, typename
concerned_conteneurs_recv
 mapping between received atoms and the mask giving ownership to each subsets in chrage
concerned_conteneurs_sent
 mapping between sent atoms and the mask giving ownership to each subsets in chrage
std::vector< ContenerTableauRefAtome<
Ref > * >
conteneurs
 contener in charge (management of atom subsets )
bool have_changed
 flag to notify if updating of attached references needed
std::map< Ref, Ref, typename
moved
 mapping between moved atoms old ref and new ref
Ref > >
newatoms
 new atoms generated by migration (received)
int rank
sent
 mapping between sent atom ref and new proc owner
Ref > >
sent_byproc
 inverse mapping : sent atoms sorted by receiving processors
std::vector< std::map< Ref,
int, typename Ref::RefComparator > >
trous
 holes created by migration in subsets conteners
MPI_Comm worldCom
Detailed Description
template<typename Ref>
class ReferenceManager< Ref >
Definition at line 51 of file reference_manager.h.
Constructor & Destructor Documentation
virtual ReferenceManager< Ref >::~ReferenceManager (  )  [inline, virtual]
Definition at line 55 of file reference_manager.h.
00055                              {
00056     for (unsigned int i = 0 ; i < conteneurs.size(); ++i)
00057       if (conteneurs[i])
00058         delete conteneurs[i];
00059   };
ReferenceManager< Ref >::ReferenceManager ( MPI_Comm  c  )  [inline]
Definition at line 61 of file reference_manager.h.
00061                               :have_changed(false),worldCom(c){
00062     if (worldCom != MPI_COMM_NULL)
00063       MPI_Comm_rank(worldCom,&rank);
00064   };
Member Function Documentation
void ReferenceManager< Ref >::AdjustSizeRecvBuffers ( std::map< int, std::vector< double > > &  recv_buffer,
std::map< int, std::vector< int > > &  recv_buffer2
) [inline, protected]
Definition at line 573 of file reference_manager.cpp.
References ReferenceManager< Ref >::attached_duo, ReferenceManager< Ref >::attached_vectors, ReferenceManager< Ref >::concerned_conteneurs_recv, ReferenceManager< Ref >::conteneurs, DBG_INFO, DUMP, ReferenceManager< Ref >::newatoms, and PROC_INVALID.
Referenced by ReferenceManager< Ref >::ExchangeSubSetAttachedValues().
00574        {
00575   int proc,size;
00576   //pour le calcul de la taille du packet par processeur (de reception)
00577   std::map<int,int> buffer_size;
00578   std::map<int,int> buffer_size2;
00579
00580
00581   /****************************************************************/
00582   //partie reception
00583   /****************************************************************/
00584
00585   //boucle sur les sous-ensembles
00586   int nb = conteneurs.size();
00587   for (int subset = 0; subset < nb ; ++subset){
00588     //boucle sur les vecteurs attachés
00589     std::vector<double *> & attached = attached_vectors[subset];
00590     std::vector<void *> & attached_duo_ = attached_duo[subset];
00591
00592     // je parcours les atomes envoyés sur les autres processeurs
00593     typename map<int,vector<Ref> >::iterator it = newatoms.begin();
00594     typename map<int,vector<Ref> >::iterator last = newatoms.end();
00595
00596     //boucle sur mes processeurs qui m'envoient
00597     for (it = newatoms.begin();it != last ; ++it){
00598       proc = (*it).first;
00599       if (proc == PROC_INVALID) continue;
00600       size = (*it).second.size();
00601       vector<Ref> & atoms = (*it).second;
00602
00603       Ref at;
00604       int mask;
00605       //loop over received atoms
00606       for (int i = 0; i < size ; ++i){
00607         at = atoms[i];
00608         if (!at.IsValid())continue;
00609         mask = concerned_conteneurs_recv[at];
00610
00611         DUMP("atome " << i << " index " << at << " mask = " << mask << " from " << proc,DBG_INFO);
00612
00613         if ((mask & (1<<subset))==0)
00614           continue;
00615
00616         //sinon la taille du buffer de reception est augmentee du nombre de vecteur attachés
00617         DUMP("adding " << attached.size() << " to buffer from " << proc,DBG_INFO);
00618         buffer_size[proc] += attached.size();
00619         DUMP("adding " << attached_duo_.size() << " to buffer from " << proc,DBG_INFO);
00620         buffer_size2[proc] += attached_duo_.size();
00621       }
00622     }
00623   }
00624
00625
00626   //set the sizes
00627   std::map<int,int>::iterator it = buffer_size.begin();
00628   std::map<int,int>::iterator last = buffer_size.end();
00629
00630   while (it != last){
00631     int proc = (*it).first;
00632     recv_buffer[proc].resize((*it).second);
00633     ++it;
00634   }
00635
00636   it = buffer_size2.begin();
00637   last = buffer_size2.end();
00638
00639   while (it != last){
00640     int proc = (*it).first;
00641     recv_buffer2[proc].resize((*it).second);
00642     ++it;
00643   }
00644
00645
00646 }
void ReferenceManager< Ref >::AnalyseSubSets (  )  [inline, protected]
Definition at line 1026 of file reference_manager.cpp.
References ReferenceManager< Ref >::concerned_conteneurs_sent, ReferenceManager< Ref >::conteneurs, DBG_ALL, DBG_ERROR, DBG_INFO, DUMP, FATAL, ReferenceManager< Ref >::moved, PROC_INVALID, ReferenceManager< Ref >::sent, ReferenceManager< Ref >::trous, and ReferenceManager< Ref >::worldCom.
Referenced by ReferenceManager< Ref >::UpdateRefSubSets().
01026                                           {
01027   //bool testing = false;
01028
01029   //parcours des conteneur dont j'ai la charge
01030   int nb = conteneurs.size();
01031   trous.resize(nb);
01032
01033   for (int subset = 0; subset < nb ; ++subset){
01034     DUMP("analysing subset " << subset << " with name " << conteneurs[subset]->name,DBG_INFO);
01035     int compteur_atoms_implique = 0;
01036     if (trous[subset].empty() == false) FATAL("probleme : la liste des trous n'est pas vide au demarrage");
01037     int nbElems = conteneurs[subset]->nbElem();
01038     //sauvegarde l'etat du conteneur pour verifier la coherence apres migration
01039 #ifdef DEBUG_REFERENCEMANAGER
01040     conteneurs[subset]->save_global_size(worldCom);
01041 #endif
01042     DUMP("Analysing subset " << subset << "/" << nb << "(" << nbElems << " - " << &conteneurs[subset] << ")",DBG_INFO);
01043     for (int j = 0 ; j < nbElems ; ++j){
01044       // attention ceci est une reference pas un objet que l'on a copie
01045       Ref at = conteneurs[subset]->Get(j);
01046       //si je suis deja sur un atome non local je continue
01047       if (!at.IsLocal()) continue;
01048       // si l'atome a change de processeur je l'invalide
01049       //et je lui note le nouveau proc .. des fois qu'il en
01050       // ai besoin
01051       DUMP("testing atom " << at,DBG_ALL);
01052       if (sent.count(at)>0){
01053         if (sent[at] == PROC_INVALID) continue;
01054         //testing = true;
01055         DUMP("invalidating atom in subset " << subset << " numero " << j
01056              << " old position = " << at << " sent to proc " << sent[at],DBG_INFO);
01057         conteneurs[subset]->Get(j).SetAway(sent[at]);
01058         if (conteneurs[subset]->Get(j).IsLocal()){
01059           FATAL("forcement aussi si meme ca ca marche pas ou va le monde");
01060         }
01061         if (trous[subset].count(at) != 0) FATAL("it seems that the atome " << at << " is present two times "
01062                                                 << "in subset " << subset << " " << conteneurs[subset]->name);
01063         trous[subset][at] = j;
01064         int mask = 1 << subset;
01065         ++compteur_atoms_implique;
01066         //si c un atome non valide issue de forwarding je fixe le masque a 0
01067         //mais je le laisse car il est compte il faut donc envoyer aussi
01068         if (!conteneurs[subset]->Get(j).IsValid()){
01069           FATAL("pourkoi il passe la ce con");
01070           mask = 0;
01071         }
01072         if (concerned_conteneurs_sent.count(at) == 0)
01073           concerned_conteneurs_sent[at] = mask;
01074         else
01075           concerned_conteneurs_sent[at] |= mask;
01076       }
01077       //si l'atome a bouge je met a jour sa ref
01078       else if (moved.count(at)>0){
01079         //testing = true;
01080         DUMP("moving atom in subset " << subset << " numero " << j << " from position " << at << " to position " << moved[at],DBG_INFO);
01081         conteneurs[subset]->Get(j) = moved[at];
01082       }
01083     }
01084     DUMP("end subset " << subset,DBG_INFO);
01085     DUMP("in subset " << conteneurs[subset]->name << " i notified " <<  compteur_atoms_implique
01086          << " over " << nbElems << " in total",DBG_ERROR);
01087   }
01088
01089 #ifdef DEBUG_REFERENCEMANAGER
01090   //pour le debug
01091   if (testing)
01092     for (int subset = 0; subset < nb ; ++subset){
01093       int nbElems = conteneurs[subset]->nbElem();
01094       DUMP("Analysing subset " << subset << "/" << nb << "(" << nbElems << " - " << &conteneurs[i] << ")");
01095       for (int j = 0 ; j < nbElems ; ++j){
01096         Ref at1 = conteneurs[subset]->Get(j);
01097         if (!at1.IsLocal()) continue;
01098         for (int k = j+1 ; k < nbElems ; ++k){
01099           Ref at2 = conteneurs[subset]->Get(k);
01100           if (!at2.IsLocal()) continue;
01101
01102           if (at1.index_atome == at2.index_atome){
01103             FATAL("houston on a un probleme : in subset " << subset << " indexes " << j << " and "
01104                   << k << " refers to the same atom " << at1.index_atome);
01105           }
01106         }
01107       }
01108     }
01109 #endif
01110 }
void ReferenceManager< Ref >::AttachDuoDistributedVector ( void *  v,
ContenerTableauRefAtome< Ref > *  c
) [inline]
Definition at line 1114 of file reference_manager.cpp.
References ReferenceManager< Ref >::attached_duo, ReferenceManager< Ref >::conteneurs, DBG_INFO_STARTUP, and DUMP.
01114        {
01115   int nb = conteneurs.size();
01116   int i=0;
01117   for (i = 0; i < nb ; ++i){
01118     if (conteneurs[i] == c){
01119       DUMP("attaching duo * " << v << " to subset " << i,DBG_INFO_STARTUP);
01120       attached_duo[i].push_back(v);
01121       break;
01122     }
01123   }
01124   if (i == nb)
01125     DUMP("attaching double * " << v << " did not found its subset",DBG_INFO_STARTUP);
01126
01127 }
void ReferenceManager< Ref >::AttachVector ( double *  v,
) [inline]
Definition at line 1131 of file reference_manager.cpp.
References ReferenceManager< Ref >::attached_vectors, ReferenceManager< Ref >::conteneurs, DBG_INFO, DUMP, and FATAL.
01131        {
01132   int nb = conteneurs.size();
01133   int i=0;
01134   for (i = 0; i < nb ; ++i){
01135     if (conteneurs[i] == c){
01136       DUMP("attaching double * " << v << " to subset " << i,DBG_INFO);
01137       attached_vectors[i].push_back(v);
01138       break;
01139     }
01140   }
01141   if (i == nb)
01142     FATAL("attaching double * " << v << " did not found its subset");
01143
01144
01145 }
void ReferenceManager< Ref >::BuildSendingBuffers ( std::map< int, std::vector< double > > &  send_buffer,
std::map< int, std::vector< int > > &  send_buffer2
Definition at line 650 of file reference_manager.cpp.
References ReferenceManager< Ref >::attached_duo, ReferenceManager< Ref >::attached_vectors, ReferenceManager< Ref >::concerned_conteneurs_sent, ReferenceManager< Ref >::conteneurs, DBG_INFO, DUMP, PROC_INVALID, ReferenceManager< Ref >::sent_byproc, and ReferenceManager< Ref >::trous.
00651        {
00652
00653
00654 //   char temp[256];
00655 //   sprintf(temp,"%d",my_proc_id);
00656 //   std::string output_file = ""; output_file += temp ;
00657 //   output_file += "bugdemerdesend.log";
00658 //   std::ofstream fout(output_file.c_str(),ios_base::out);
00659
00660   int proc, size;
00661   /****************************************************************/
00662   //partie envoi
00663   /****************************************************************/
00664
00665
00666   std::map<Ref,std::map<int,std::vector<int> >,typename Ref::RefComparator> attached_values_duo_check;
00667
00668   //boucle sur les sous-ensembles
00669   int nb = conteneurs.size();
00670   for (int subset = 0; subset < nb ; ++subset){
00671     // je parcours les atomes envoyés sur les autres processeurs
00672     typename map<int,vector<Ref> >::iterator it = sent_byproc.begin();
00673     typename map<int,vector<Ref> >::iterator last = sent_byproc.end();
00674
00675     //boucle sur mes processeurs qui m'envoient
00676     for (it = sent_byproc.begin();it != last ; ++it){
00677       proc = (*it).first;
00678       if (proc == PROC_INVALID) continue;
00679       size = (*it).second.size();
00680       vector<Ref> & atoms = (*it).second;
00681
00682       Ref at;
00683       int mask;
00684       //boucle sur les atomes envoyes
00685       for (int i = 0; i < size ; ++i){
00686         // je skip les atomes qui sont pas dans le groupe actuel
00687         at = atoms[i];
00688         if (!at.IsValid())continue;
00689         mask = concerned_conteneurs_sent[at];
00690
00691         //      if (proc == 7) fout << "atome " << i << " ref : " << at << " mask = " << mask << std::endl;
00692
00693         if ((mask & (1<<subset))==0)
00694           continue;
00695
00696         DUMP("atome " << i << " index " << at << " mask = " << mask << " from " << proc,DBG_INFO);
00697
00698
00699
00700         //sinon je dois stocker les informations relatives aux atomes envoyes
00701         int index_in_subset = trous[subset][at];
00702         //boucle sur les vecteurs attachés
00703         std::vector<double *> & attached = attached_vectors[subset];
00704         std::vector<void *> & attached_duo_ = attached_duo[subset];
00705
00706
00707         DUMP("first manage " << attached.size() << " vectors attached to subset " << subset,DBG_INFO);
00708         for (unsigned int v = 0; v < attached.size();++v){
00709           double * vector = attached[v];
00710           send_buffer[proc].push_back(vector[index_in_subset]);
00711           DUMP("adding " << vector[index_in_subset] << " to send buffer for " << proc,DBG_INFO);
00712         }
00713
00714         DUMP("now manage " << attached_duo_.size() << " duo vectors attached to subset " << subset,DBG_INFO);
00715         for (unsigned int v = 0; v < attached_duo_.size();++v){
00716           DuoDistributedVecteur * duo = (DuoDistributedVecteur*)attached_duo_[v];
00717           DUMP("treating trou " << index_in_subset << " created by moving on proc " << proc << " for subset "
00718                << conteneurs[subset]->name << " duo " << duo << " for proc " << proc,DBG_INFO);
00719           DUMP("adding " << duo->GetNeighbor(index_in_subset) << " to send buffer2 for " << proc << " with mask = " << mask
00720                << "at position in buffer " << send_buffer2[proc].size(),DBG_INFO);
00721           send_buffer2[proc].push_back(duo->GetNeighbor(index_in_subset));
00722           //      if (proc == 7) fout << "attached value atom " << i << " attached duo " << v << " subset "
00723           //          << subset << " : " << send_buffer2[proc][send_buffer2[proc].size()-1] << std::endl;
00724           attached_values_duo_check[at][subset].push_back(send_buffer2[proc][send_buffer2[proc].size()-1]);
00725           duo->sendAtom(index_in_subset,proc);
00726         }
00727       }
00728     }
00729   }
00730
00731 //   fout.close();
00732
00733   //bilan pour controle sur la preparation des buffers
00734   std::map<int,std::map<int,int> > cpt_sent;
00735   std::map<int,std::map<int,int> > cpt_sent_brut;
00736   {
00737     typename std::map<Ref,std::map<int,std::vector<int> >,typename Ref::RefComparator>::iterator it = attached_values_duo_check.begin();
00738     typename std::map<Ref,std::map<int,std::vector<int> >,typename Ref::RefComparator>::iterator last = attached_values_duo_check.end();
00739
00740     while (it != last){
00741       Ref at = (*it).first;
00742       int nb = conteneurs.size();
00743       for (int subset = 0; subset < nb ; ++subset){
00744         if (((*it).second).count(subset) == 0) continue;
00745         std::map<int,int> & map = cpt_sent[subset];
00746         std::vector<int> & v = ((*it).second)[subset];
00747         for (unsigned int i = 0 ; i < v.size(); ++i){
00748           int value = v[i];
00749           if (map.count(value) == 0 ) map[value] = 0;
00750           ++map[value];
00751         }
00752       }
00753       ++it;
00754     }
00755   }
00756
00757
00758
00759   {
00760     std::map<int,std::vector<int> >::iterator it = send_buffer2.begin();
00761     std::map<int,std::vector<int> >::iterator last = send_buffer2.end();
00762
00763     while (it != last){
00764       int proc = (*it).first;
00765       std::vector<int> & v = (*it).second;
00766       std::map<int,int> & map = cpt_sent_brut[proc];
00767       for (unsigned int i = 0 ; i < v.size() ; ++i){
00768         int value = v[i];
00769         if (map.count(value) == 0 )map[value] = 0;
00770         ++map[value];
00771       }
00772       ++it;
00773     }
00774   }
00775
00776
00777   DUMP("BEGIN *********************************",DBG_INFO);
00778   {
00779     std::map<int,std::map<int,int> >::iterator it =  cpt_sent_brut.begin();
00780     std::map<int,std::map<int,int> >::iterator last = cpt_sent_brut.end();
00781     while (it != last){
00782       std::map<int,int>::iterator it2 =  (*it).second.begin();
00783       std::map<int,int>::iterator last2 = (*it).second.end();
00784       while (it2 != last2){
00785         DUMP("bilan sent brut for proc " << (*it).first <<
00786              " for dist owner stored " << (*it2).first <<
00787              " quantity :" << (*it2).second,DBG_INFO);
00788         ++it2;
00789       }
00790       ++it;
00791     }
00792
00793     it =  cpt_sent.begin();
00794     last = cpt_sent.end();
00795     while (it != last){
00796       std::map<int,int>::iterator it2 =  (*it).second.begin();
00797       std::map<int,int>::iterator last2 = (*it).second.end();
00798       while (it2 != last2){
00799         DUMP("bilan sent for subset " << (*it).first <<
00800              " for dist owner stored " << (*it2).first <<
00801              " quantity :" << (*it2).second,DBG_INFO);
00802         ++it2;
00803       }
00804       ++it;
00805     }
00806   }
00807   DUMP("END *********************************",DBG_INFO);
00808
00809 }
void ReferenceManager< Ref >::CheckSubSetsCardinal (  )  [inline, protected]
Definition at line 1018 of file reference_manager.cpp.
References ReferenceManager< Ref >::conteneurs, and ReferenceManager< Ref >::worldCom.
01018                                                 {
01019   int nb = conteneurs.size();
01020   for (int subset = 0; subset < nb ; ++subset){
01021     conteneurs[subset]->check_parallel_coherence(worldCom);
01022   }
01023 }
void ReferenceManager< Ref >::ClearSTL (  )  [inline, protected]
Definition at line 176 of file reference_manager.cpp.
References ReferenceManager< Ref >::attached_values, ReferenceManager< Ref >::attached_values_duo, ReferenceManager< Ref >::concerned_conteneurs_recv, ReferenceManager< Ref >::concerned_conteneurs_sent, ReferenceManager< Ref >::moved, ReferenceManager< Ref >::newatoms, ReferenceManager< Ref >::sent, ReferenceManager< Ref >::sent_byproc, and ReferenceManager< Ref >::trous.
00176                                     {
00177   concerned_conteneurs_sent.clear();
00178   concerned_conteneurs_recv.clear();
00179   trous.clear();
00180   moved.clear();
00181   sent.clear();
00182   sent_byproc.clear();
00183   newatoms.clear();
00184   attached_values.clear();
00185   attached_values_duo.clear();
00186 }
void ReferenceManager< Ref >::CreationExchangedAtomsInSubSets (  )  [inline, protected]
Definition at line 926 of file reference_manager.cpp.
References ReferenceManager< Ref >::attached_duo, ReferenceManager< Ref >::attached_values, ReferenceManager< Ref >::attached_values_duo, ReferenceManager< Ref >::attached_vectors, ReferenceManager< Ref >::concerned_conteneurs_recv, ReferenceManager< Ref >::conteneurs, DBG_ERROR, DBG_INFO, DBG_INFO_STARTUP, DUMP, and ReferenceManager< Ref >::trous.
00926                                                            {
00927
00928
00929   DUMP("creation of atoms in concerned subsets",DBG_INFO_STARTUP);
00930
00931   //je parcours les atomes crés sur ce processeur
00932   typename map<Ref,int,typename Ref::RefComparator>::iterator it = concerned_conteneurs_recv.begin();
00933   typename map<Ref,int,typename Ref::RefComparator>::iterator last = concerned_conteneurs_recv.end();
00934
00935  std::map<int,int> compteur_atoms_created;
00936
00937   for (it = concerned_conteneurs_recv.begin();it != last ; ++it){
00938     int mask = (*it).second;
00939     Ref at = (*it).first;
00940     if (!at.IsValid()) continue;
00941     DUMP("mask = " << mask,DBG_INFO);
00942     //parcours des conteneur dont j'ai la charge
00943     int nb = conteneurs.size();
00944     double * vector;
00945
00946
00947     for (int subset = 0; subset < nb ; ++subset){
00948       if ((mask & (1<<subset))==0)
00949         continue;
00950
00951       ++compteur_atoms_created[subset];
00952
00953       // je regarde si il y a des trous que je peux boucher
00954       std::map<Ref,int,typename Ref::RefComparator> & trous_subset = trous[subset];
00955       int new_index;
00956
00957       if (trous_subset.size() > 0){
00958         DUMP("j'utilise un trou pour mettre ma nouvelle reference ",DBG_INFO);
00959         typename std::map<Ref,int,typename Ref::RefComparator>::iterator first_entry = trous_subset.begin();
00960         Ref oldat = (*first_entry).first;
00961         new_index = (*first_entry).second;
00962         conteneurs[subset]->Get(new_index) = at;
00963         trous_subset.erase(oldat);
00964       }
00965       else{
00966         DUMP("ma nouvelle reference est placee a la fin",DBG_INFO);
00967         //sinon j'ajoute l'atome par la voie standard ie au bout du vecteur
00968         new_index = conteneurs[subset]->nbElem();
00969         conteneurs[subset]->Ajouter(at);
00970      }
00971
00972       DUMP("treating(creation atom) subset number " << subset << " new atome at index " << new_index,DBG_INFO);
00973
00974       // je parcours maintenant les vecteurs attachés
00975       std::vector<double *> & attached = attached_vectors[subset];
00976
00977       for (unsigned int i = 0 ; i < attached.size(); ++i){
00978         vector = attached[i];
00979         DUMP("assigning attached vector " << i << " (internal index = " << at << ")",DBG_INFO);
00980         vector[new_index] = attached_values[at][subset][i];
00981       }
00982
00983 //       std::vector<unsigned int *> & attached_size = attached_sizes[subset];
00984 //       for (unsigned int i = 0 ; i < attached_size.size(); ++i){
00985 //      unsigned int * s = attached_size[i];
00986 //       DUMP("incresing size assigning attached vector " << i << " (internal index = " << at << ")");
00987 //      vector[new_index] = attached_values[at][subset][i];
00988 //       }
00989
00990
00991       std::vector<void *> & attached_duo_ = attached_duo[subset];
00992       // je parcours maintenant les duovecteurs attaches
00993       DUMP("declaring received atoms on the " << attached_duo_.size() << " attached duo vectors",DBG_INFO);
00994       for (unsigned int i = 0 ; i < attached_duo_.size(); ++i){
00995         DuoDistributedVecteur * duo = (DuoDistributedVecteur *)attached_duo_[i];
00996         DUMP("assigning attached duo " << i << "(" << duo << ")" << " while mask = " << mask << " for subset " << conteneurs[subset]->name
00997              << " and as for new neighbor = " << attached_values_duo[at][subset][i] << " and at " << at,DBG_INFO);
00998         duo->receiveAtom(new_index,attached_values_duo[at][subset][i]);
00999       }
01000
01001     }
01002   }
01003
01004   int nb = conteneurs.size();
01005   for (int subset = 0; subset < nb ; ++subset){
01006     DUMP("in subset " << conteneurs[subset]->name << " i created " <<  compteur_atoms_created[subset]
01007          << " over " << concerned_conteneurs_recv.size() << " in total",DBG_ERROR);
01008   }
01009
01010
01011   DUMP("end CreationExchangedAtomsInSubSets",DBG_INFO);
01012 }
void ReferenceManager< Ref >::DecodeBuffers ( std::map< int, std::vector< double > > &  recv_buffer,
Definition at line 400 of file reference_manager.cpp.
References ReferenceManager< Ref >::attached_duo, ReferenceManager< Ref >::attached_values, ReferenceManager< Ref >::attached_values_duo, ReferenceManager< Ref >::attached_vectors, ReferenceManager< Ref >::concerned_conteneurs_recv, ReferenceManager< Ref >::conteneurs, DBG_INFO, DUMP, FATAL, ReferenceManager< Ref >::newatoms, and PROC_INVALID.
00401        {
00402
00403
00404 //   if (recv_buffer2.count(8)>0 && recv_buffer2[8].size() > 1)
00405 //     DUMP("BBBBBBBBBBBBBBBBB " << recv_buffer2[8][0],DBG_INFO);
00406
00407 //   char temp[256];
00408 //   sprintf(temp,"%d",my_proc_id);
00409 //   std::string output_file = ""; output_file += temp ;
00410 //   output_file += "bugdemerderecv.log";
00411 //   std::ofstream fout(output_file.c_str(),ios_base::out);
00412
00413
00414   /****************************************************************/
00415   //phase de decodage du paquet groupe des valeurs attaches
00416   /****************************************************************/
00417
00418   //boucle sur les sous-ensembles
00419   int nb = conteneurs.size();
00420   int proc,size;
00421
00422   std::map<int,int> index;
00423   std::map<int,int> index2;
00424
00425   for (int subset = 0; subset < nb ; ++subset){
00426     //boucle sur les vecteurs attachés
00427     std::vector<double *> & attached = attached_vectors[subset];
00428     std::vector<void *> & attached_duo_ = attached_duo[subset];
00429
00430     // je parcours les atomes envoyés sur les autres processeurs
00431     typename map<int,vector<Ref> >::iterator it = newatoms.begin();
00432     typename map<int,vector<Ref> >::iterator last = newatoms.end();
00433
00434
00435     //boucle sur mes processeurs qui m'envoient
00436     for (it = newatoms.begin();it != last ; ++it){
00437       proc = (*it).first;
00438
00439       if (index.count(proc) == 0) index[proc] = 0;
00440       if (index2.count(proc) == 0) index2[proc] = 0;
00441
00442       if (proc == PROC_INVALID)continue;
00443       size = (*it).second.size();
00444       vector<Ref> & atoms = (*it).second;
00445
00446       Ref at;
00447       int mask;
00448
00449       //boucle sur les atomes recus
00450       for (int i = 0; i < size ; ++i){
00451         at = atoms[i];
00452         if (!at.IsValid())continue;
00453         if (concerned_conteneurs_recv.count(at) == 0) FATAL("bipbipbipbipbip " << at);
00454         mask = concerned_conteneurs_recv[at];
00455
00456         //      if (proc == 8) fout << "atome " << i << " ref : " << at << " mask = " << mask <<std::endl;
00457
00458         // je skip les atomes qui sont pas dans le groupe actuel
00459         if ((mask & (1<<subset))==0)
00460           continue;
00461
00462         DUMP("atome " << i << " index " << at << " mask = " << mask << " from " << proc,DBG_INFO);
00463
00464         //parcours sur les vecteurs attaches
00465         for (unsigned int j = 0; j < attached.size() ; ++j){
00466           DUMP("reading attached value atom " << i << " attached vector " << j << " subset "
00467                << subset << " : " << recv_buffer[proc][index[proc]] << " (internal index = "
00468                << at << ")" << proc,DBG_INFO);
00469           if (index[proc] >= recv_buffer[proc].size()) FATAL("depassement detecte " << index[proc] << " " << recv_buffer[proc].size());
00470           attached_values[at][subset].push_back(recv_buffer[proc][index[proc]]);
00471           ++index[proc];
00472         }
00473
00474         //parcours sur les vecteurs attaches duo
00475         DUMP("Decoding received packet onto the " << attached_duo_.size() << " duo vectors",DBG_INFO);
00476         for (unsigned int j = 0; j < attached_duo_.size() ; ++j){
00477           DUMP("reading attached value atom " << i << " attached duo " << j << " subset "
00478                << subset << " : " << recv_buffer2[proc][index2[proc]] << " (internal index = "
00479                << at << ")",DBG_INFO);
00480           //      if (proc == 8) fout << "attached value atom " << i << " attached duo " << j << " subset "
00481           //          << subset << " : " << recv_buffer2[proc][index2[proc]] << std::endl;
00482           if (index2[proc] >= recv_buffer2[proc].size()) FATAL("depassement detecte " << index2[proc] << " " << recv_buffer2[proc].size());
00483           attached_values_duo[at][subset].push_back(recv_buffer2[proc][index2[proc]]);
00484           //      if (i == 145) DUMP("AAAAAAAAAAAAAAAAAAAAAAA youhou " << index2,DBG_INFO);
00485           ++index2[proc];
00486         }
00487
00488       }
00489     }
00490   }
00491   //  fout.close();
00492
00493   if (recv_buffer2.count(8)>0 && recv_buffer2[8].size() > 1)
00494   DUMP("BBBBBBBBBBBBBBBBB " << recv_buffer2[8][0],DBG_INFO);
00495
00496   //print bilan of exchange subset values to screen use for debug only
00497   std::map<int,std::map<int,int> > cpt_recv;
00498   std::map<int,std::map<int,int> > cpt_recv_brut;
00499   {
00500     typename std::map<Ref,std::map<int,std::vector<int> >,typename Ref::RefComparator>::iterator it = attached_values_duo.begin();
00501     typename std::map<Ref,std::map<int,std::vector<int> >,typename Ref::RefComparator>::iterator last = attached_values_duo.end();
00502
00503     while (it != last){
00504       Ref at = (*it).first;
00505       int nb = conteneurs.size();
00506       for (int subset = 0; subset < nb ; ++subset){
00507         if (((*it).second).count(subset) == 0) continue;
00508         std::map<int,int> & map = cpt_recv[subset];
00509         std::vector<int> & v = ((*it).second)[subset];
00510         for (unsigned int i = 0 ; i < v.size(); ++i){
00511           int value = v[i];
00512           if (map.count(value) == 0 ) map[value] = 0;
00513           ++map[value];
00514         }
00515       }
00516       ++it;
00517     }
00518   }
00519
00520
00521   {
00522     std::map<int,std::vector<int> >::iterator it = recv_buffer2.begin();
00523     std::map<int,std::vector<int> >::iterator last = recv_buffer2.end();
00524
00525     while (it != last){
00526       int proc = (*it).first;
00527       std::vector<int> & v = (*it).second;
00528       std::map<int,int> & map = cpt_recv_brut[proc];
00529       for (unsigned int i = 0 ; i < v.size() ; ++i){
00530         int value = v[i];
00531         if (map.count(value) == 0 )map[value] = 0;
00532         ++map[value];
00533       }
00534       ++it;
00535     }
00536   }
00537
00538   DUMP("BEGIN *********************************",DBG_INFO);
00539   {
00540     std::map<int,std::map<int,int> >::iterator it =  cpt_recv_brut.begin();
00541     std::map<int,std::map<int,int> >::iterator last = cpt_recv_brut.end();
00542     while (it != last){
00543       std::map<int,int>::iterator it2 =  (*it).second.begin();
00544       std::map<int,int>::iterator last2 = (*it).second.end();
00545       while (it2 != last2){
00546         DUMP("bilan recv brut from proc " << (*it).first <<
00547              " for dist owner stored " << (*it2).first <<
00548              " quantity :" << (*it2).second,DBG_INFO);
00549         ++it2;
00550       }
00551       ++it;
00552     }
00553
00554     it =  cpt_recv.begin();
00555     last = cpt_recv.end();
00556     while (it != last){
00557       std::map<int,int>::iterator it2 =  (*it).second.begin();
00558       std::map<int,int>::iterator last2 = (*it).second.end();
00559       while (it2 != last2){
00560         DUMP("bilan recv for subset " << (*it).first <<
00561              " for dist owner stored " << (*it2).first <<
00562              " quantity :" << (*it2).second,DBG_INFO);
00563         ++it2;
00564       }
00565       ++it;
00566     }
00567   }
00568   DUMP("END *********************************",DBG_INFO);
00569
00570 }
void ReferenceManager< Ref >::ExchangeSubSetAttachedValues (  )  [inline, protected]
Definition at line 814 of file reference_manager.cpp.
References ReferenceManager< Ref >::AdjustSizeRecvBuffers(), ReferenceManager< Ref >::BuildSendingBuffers(), DBG_INFO, ReferenceManager< Ref >::DecodeBuffers(), DUMP, ReferenceManager< Ref >::newatoms, PROC_INVALID, ReferenceManager< Ref >::rank, ReferenceManager< Ref >::sent_byproc, and ReferenceManager< Ref >::worldCom.
00814                                                         {
00815   DUMP("ExchangeSubSetAttachedValues",DBG_INFO);
00816
00817   int proc;
00818   int size;
00819
00820   std::map<int,std::vector<double> > send_buffer;
00821   std::map<int,std::vector<double> > recv_buffer;
00822
00823   std::map<int,std::vector<int> > send_buffer2;
00824   std::map<int,std::vector<int> > recv_buffer2;
00825
00826   BuildSendingBuffers(send_buffer,send_buffer2);
00827   //  DUMP("INITINIT " << send_buffer2[1][145],DBG_INFO);
00828   AdjustSizeRecvBuffers(recv_buffer,recv_buffer2);
00829   //  DUMP("INITINIT " << send_buffer2[1][145],DBG_INFO);
00830
00831   /****************************************************************/
00832   // partie communication
00833   /****************************************************************/
00834
00835   map<int,MPI_Request> recv_requests;
00836   map<int,MPI_Request> recv_requests2;
00837
00838   //phase de reception asynchrone
00839   {
00840     typename map<int,vector<Ref> >::iterator it = newatoms.begin();
00841     typename map<int,vector<Ref> >::iterator last = newatoms.end();
00842
00843     //boucle sur mes processeurs destinataires
00844     for (it = newatoms.begin();it != last ; ++it){
00845       proc = (*it).first;
00846       if (proc == PROC_INVALID) continue;
00847       size = recv_buffer[proc].size();
00848       if (size>0){
00849         DUMP("a buffer of size " << size << " doubles will be received from proc " << proc
00850              << " for attached values",DBG_INFO);
00851         MPI_Request & request = recv_requests[proc];
00852         MPI_Irecv(&recv_buffer[proc][0],size,MPI_DOUBLE,proc,proc+1,worldCom,&request);
00853       }
00854       size = recv_buffer2[proc].size();
00855       if (size>0){
00856         DUMP("a buffer of size " << size << " integers will be received from proc " << proc
00857              << " for attached duos",DBG_INFO);
00858         MPI_Request & request = recv_requests2[proc];
00859         MPI_Irecv(&recv_buffer2[proc][0],size,MPI_INT,proc,proc+2,worldCom,&request);
00860       }
00861     }
00862   }
00863
00864   //phase d'envoi
00865   {
00866     typename map<int,vector<Ref> >::iterator it = sent_byproc.begin();
00867     typename map<int,vector<Ref> >::iterator last = sent_byproc.end();
00868
00869     //boucle sur mes processeurs destinataires
00870     for (it = sent_byproc.begin();it != last ; ++it){
00871       proc = (*it).first;
00872       if (proc == PROC_INVALID)continue;
00873       size = send_buffer[proc].size();
00874       if (size>0){
00875         DUMP("a buffer of size " << size << " double will be sent to proc " << proc
00876              << " for attached values",DBG_INFO);
00877         MPI_Send(&send_buffer[proc][0],size,MPI_DOUBLE,proc,rank+1,worldCom);
00878       }
00879
00880       size = send_buffer2[proc].size();
00881       if (size>0){
00882         DUMP("a buffer of size " << size << " integers will be sent to proc " << proc
00883              << " for attached duos",DBG_INFO);
00884         MPI_Send(&send_buffer2[proc][0],size,MPI_INT,proc,rank+2,worldCom);
00885       }
00886     }
00887   }
00888
00889   //maintenant j'attend les communication de maniere synchronisante (pour les vector)
00890   {
00891     MPI_Status status;
00892     typename map<int,MPI_Request>::iterator it = recv_requests.begin();
00893     typename map<int,MPI_Request>::iterator last = recv_requests.end();
00894
00895     for (it = recv_requests.begin();it != last ; ++it){
00896       MPI_Wait(&((*it).second),&status);
00897       proc = (*it).first;
00898       DUMP("received packet vector from proc " << proc,DBG_INFO);
00899             if(recv_buffer2.count(8)>0 && recv_buffer2[8].size() > 1)
00900       DUMP("BBBBBBBBBBBBBBBBB " << recv_buffer2[8][0],DBG_INFO);
00901     }
00902   }
00903
00904   //maintenant j'attend les communication de maniere synchronisante (pour les duos)
00905   {
00906     MPI_Status status;
00907     typename map<int,MPI_Request>::iterator it = recv_requests2.begin();
00908     typename map<int,MPI_Request>::iterator last = recv_requests2.end();
00909
00910     for (it = recv_requests2.begin();it != last ; ++it){
00911       MPI_Wait(&((*it).second),&status);
00912       proc = (*it).first;
00913       DUMP("received packet duo from proc " << proc,DBG_INFO);
00914     }
00915   }
00916
00917   DecodeBuffers(recv_buffer,recv_buffer2);
00918
00919
00920 }
Here is the call graph for this function:
void ReferenceManager< Ref >::ExchangeSubSetsMasks (  )  [inline, protected]
Definition at line 247 of file reference_manager.cpp.
References ReferenceManager< Ref >::concerned_conteneurs_recv, ReferenceManager< Ref >::concerned_conteneurs_sent, DBG_DETAIL, DBG_INFO, DUMP, FATAL, ReferenceManager< Ref >::newatoms, PROC_INVALID, ReferenceManager< Ref >::rank, ReferenceManager< Ref >::sent_byproc, and ReferenceManager< Ref >::worldCom.
00247                                                 {
00248   int proc;
00249   int size;
00250   //checking phase first
00251
00252   //maintenant que je sais quels sous ensembles sont concernes par
00253   //les changements il faut prevenir les procs distant de ce fait
00254   map<int,int> recv_buffers_check;
00255   map<int,MPI_Request> recv_requests_check;
00256
00257   {
00258     //phase de reception asynchrone
00259     typename map<int,vector<Ref> >::iterator it = newatoms.begin();
00260     typename map<int,vector<Ref> >::iterator last = newatoms.end();
00261
00262     //pour chaque processeurs qui m'ont envoyes des atomes
00263     for (it = newatoms.begin();it != last ; ++it){
00264       proc = (*it).first;
00265
00266       if (proc == PROC_INVALID)
00267         continue;
00268       size = (*it).second.size();
00269       if (size == 0) continue;
00270
00271       int & buffer = recv_buffers_check[proc];
00272       MPI_Request & request = recv_requests_check[proc];
00273       MPI_Irecv(&buffer,1,MPI_INT,proc,proc,worldCom,&request);
00274     }
00275   }
00276   {
00277     //phase d'envoi
00278     typename map<int,vector<Ref> >::iterator it = sent_byproc.begin();
00279     typename map<int,vector<Ref> >::iterator last = sent_byproc.end();
00280
00281     for (it = sent_byproc.begin();it != last ; ++it){
00282       proc = (*it).first;
00283       if (proc == PROC_INVALID) continue;
00284
00285       size = (*it).second.size();
00286       if (size == 0) continue;
00287       MPI_Send(&size,1,MPI_INT,proc,rank,worldCom);
00288     }
00289   }
00290   //maintenant j'attend les communication de maniere synchronisante
00291   {
00292     MPI_Status status;
00293     typename map<int,MPI_Request>::iterator it = recv_requests_check.begin();
00294     typename map<int,MPI_Request>::iterator last = recv_requests_check.end();
00295
00296     for (it = recv_requests_check.begin();it != last ; ++it){
00297       proc = (*it).first;
00298       if (newatoms.count(proc) == 0) FATAL("pas normal du tout");
00299       if (proc == PROC_INVALID) continue;
00300       int & buffer = recv_buffers_check[proc];
00301       DUMP("waiting for com from " << proc << " in check process",DBG_INFO);
00302       MPI_Wait(&((*it).second),&status);
00303       DUMP("ok received",DBG_INFO);
00304       if (newatoms[proc].size() != buffer) FATAL("protocol prevision failed :  " << newatoms[proc].size()
00305                                                  << " != " << buffer << " for exchange with " << proc);
00306       //je remplis la structure map concerned_conteneurs_recv (une fois recu bien sur);
00307     }
00308   }
00309
00310   //  MPI_Barrier(worldCom);
00311
00312   //real phase now
00313   //maintenant que je sais quels sous ensembles sont concernes par
00314   //les changements il faut prevenir les procs distant de ce fait
00315   map<int,std::vector<int> > recv_buffers;
00316   map<int,MPI_Request> recv_requests;
00317
00318   {
00319     //phase de reception asynchrone
00320     typename map<int,vector<Ref> >::iterator it = newatoms.begin();
00321     typename map<int,vector<Ref> >::iterator last = newatoms.end();
00322
00323     //pour chaque processeurs qui m'ont envoyes des atomes
00324     for (it = newatoms.begin();it != last ; ++it){
00325       proc = (*it).first;
00326
00327       if (proc == PROC_INVALID)
00328         continue;
00329       size = (*it).second.size();
00330       if (size == 0) continue;
00331
00332       std::vector<int> & buffer = recv_buffers[proc];
00333       MPI_Request & request = recv_requests[proc];
00334
00335       buffer.resize(size);
00336       DUMP("receiving from proc " << proc << " " << size << " integers",DBG_INFO);
00337       MPI_Irecv(&buffer[0],size,MPI_INT,proc,proc,worldCom,&request);
00338     }
00339
00340   }
00341
00342
00343   {
00344     //phase d'envoi
00345     std::vector<int> send_buffer;
00346
00347     typename map<int,vector<Ref> >::iterator it = sent_byproc.begin();
00348     typename map<int,vector<Ref> >::iterator last = sent_byproc.end();
00349
00350     for (it = sent_byproc.begin();it != last ; ++it){
00351       proc = (*it).first;
00352       if (proc == PROC_INVALID) continue;
00353
00354       size = (*it).second.size();
00355       vector<Ref> & atoms = (*it).second;
00356
00357       if (size == 0) continue;
00358
00359       send_buffer.resize(size);
00360
00361       DUMP("sending to proc " << proc << " " << size << " integers",DBG_INFO);
00362
00363      for (int i=0; i < size ; ++i){
00364        if (concerned_conteneurs_sent.count(atoms[i]) == 0)
00365          send_buffer[i] = 0;
00366        else
00367          send_buffer[i] = concerned_conteneurs_sent[atoms[i]];
00368      }
00369      MPI_Send(&send_buffer[0],size,MPI_INT,proc,rank,worldCom);
00370     }
00371   }
00372
00373   //maintenant j'attend les communication de maniere synchronisante
00374   {
00375     MPI_Status status;
00376     typename map<int,MPI_Request>::iterator it = recv_requests.begin();
00377     typename map<int,MPI_Request>::iterator last = recv_requests.end();
00378
00379     for (it = recv_requests.begin();it != last ; ++it){
00380       proc = (*it).first;
00381       if (proc == PROC_INVALID) continue;
00382
00383       std::vector<int> & buffer = recv_buffers[proc];
00384       DUMP("waiting to receive a packet from proc " << proc << " of size " << buffer.size()<< " integers",DBG_INFO);
00385       MPI_Wait(&((*it).second),&status);
00386       DUMP("received packet from proc " << proc << " of size " << buffer.size(),DBG_DETAIL);
00387       //je remplis la structure map concerned_conteneurs_recv (une fois recu bien sur);
00388       for (unsigned int i = 0 ; i < buffer.size() ; ++i){
00389         DUMP("received mask " << buffer[i] << " assoc with " << newatoms[proc][i] << " with i = " << i,DBG_INFO);
00390         if (concerned_conteneurs_recv.count(newatoms[proc][i]) != 0)
00391           FATAL("trying to set mask multiple time over same uniq atom : probably migration trouble");
00392         if (buffer[i] != 0)
00393           concerned_conteneurs_recv[newatoms[proc][i]] = buffer[i];
00394       }
00395     }
00396   }
00397 }
void ReferenceManager< Ref >::PrintBilanToScreen (  )  [inline, protected]
Definition at line 189 of file reference_manager.cpp.
References ReferenceManager< Ref >::concerned_conteneurs_recv, ReferenceManager< Ref >::concerned_conteneurs_sent, ReferenceManager< Ref >::conteneurs, DBG_INFO, and DUMP.
00189                                               {
00190   int nb = conteneurs.size();
00191   std::map<int,int> cpt_subset_sent;
00192   std::map<int,int> cpt_subset_recv;
00193
00194   {
00195     typename std::map<Ref,int,typename Ref::RefComparator>::iterator it = concerned_conteneurs_sent.begin();
00196     typename std::map<Ref,int,typename Ref::RefComparator>::iterator last = concerned_conteneurs_sent.end();
00197
00198     while (it != last){
00199       Ref at = (*it).first;
00200       int mask = (*it).second;
00201       for (int subset = 0; subset < nb ; ++subset){
00202         if (cpt_subset_sent.count(subset) == 0) cpt_subset_sent[subset] = 0;
00203         if (mask & (1<<subset)) ++cpt_subset_sent[subset];
00204       }
00205       ++it;
00206     }
00207   }
00208
00209   {
00210     typename std::map<Ref,int,typename Ref::RefComparator>::iterator it = concerned_conteneurs_recv.begin();
00211     typename std::map<Ref,int,typename Ref::RefComparator>::iterator last = concerned_conteneurs_recv.end();
00212
00213     while (it != last){
00214       Ref at = (*it).first;
00215       int mask = (*it).second;
00216       for (int subset = 0; subset < nb ; ++subset){
00217         if (cpt_subset_recv.count(subset) == 0) cpt_subset_recv[subset] = 0;
00218         if (mask & (1<<subset)) ++cpt_subset_recv[subset];
00219       }
00220       ++it;
00221     }
00222   }
00223
00224   DUMP("BEGIN *********************************",DBG_INFO);
00225   {
00226     std::map<int,int>::iterator it =  cpt_subset_sent.begin();
00227     std::map<int,int>::iterator last = cpt_subset_sent.end();
00228     while (it != last){
00229       DUMP("number of sent registered for subset " << (*it).first << " is " << (*it).second,DBG_INFO);
00230       ++it;
00231     }
00232   }
00233
00234   {
00235     std::map<int,int>::iterator it =  cpt_subset_recv.begin();
00236     std::map<int,int>::iterator last = cpt_subset_recv.end();
00237     while (it != last){
00238       DUMP("number of recv registered for subset " << (*it).first << " is " << (*it).second,DBG_INFO);
00239       ++it;
00240     }
00241   }
00242   DUMP("END *********************************",DBG_INFO);
00243 }
ContenerTableauRefAtome<Ref>& ReferenceManager< Ref >::RequestCreationSubSet ( char *  name  )  [inline]
contener of subsets need to be updated in order to fit the migrated structures
Definition at line 68 of file reference_manager.h.
00068        {
00069     int size = conteneurs.size();
00070     DUMP("creation d'un sous ensemble d'atomes (numero" << size << ") named " << name,DBG_INFO);
00071     conteneurs.resize(size+1);
00072     conteneurs[size] = new ContenerTableauRefAtome<Ref>(name);
00073     return *conteneurs[size];
00074   }
void ReferenceManager< Ref >::UpdateRefSubSets (  )  [inline]
Definition at line 64 of file reference_manager.cpp.
References ReferenceManager< Ref >::AnalyseSubSets(), ReferenceManager< Ref >::CheckSubSetsCardinal(), ReferenceManager< Ref >::ClearSTL(), ReferenceManager< Ref >::CreationExchangedAtomsInSubSets(), DBG_ERROR, DBG_INFO, DBG_WARNING, DUMP, ReferenceManager< Ref >::ExchangeSubSetAttachedValues(), ReferenceManager< Ref >::ExchangeSubSetsMasks(), ReferenceManager< Ref >::have_changed, ReferenceManager< Ref >::moved, ReferenceManager< Ref >::newatoms, ReferenceManager< Ref >::PrintBilanToScreen(), ReferenceManager< Ref >::sent, ReferenceManager< Ref >::sent_byproc, and ReferenceManager< Ref >::worldCom.
Referenced by UpdateRefSubSets().
00064                                             {
00065   MPI_Barrier(worldCom);
00066
00067   if (have_changed)
00068   DUMP("have_changed = " << have_changed,DBG_ERROR);
00069   if (have_changed==false){
00070     MPI_Barrier(worldCom);
00071     MPI_Barrier(worldCom);
00072     MPI_Barrier(worldCom);
00073     MPI_Barrier(worldCom);
00074     MPI_Barrier(worldCom);
00075     return;
00076   }
00077 //    sleep(my_proc_id);
00078
00079   if (moved.size() > 0){
00080     DUMP(moved.size() << " atoms moved in memory",DBG_INFO);
00081   }
00082
00083   {
00084     typename map<int,vector<Ref> >::iterator it = newatoms.begin();
00085     typename map<int,vector<Ref> >::iterator last = newatoms.end();
00086
00087     for (it = newatoms.begin();it != last;++it){
00088       DUMP((*it).second.size() << " atoms received from proc " << (*it).first,DBG_INFO);
00089       //       for (unsigned int k = 0 ; k < (*it).second.size() ; ++k){
00090       //        LOG("received atom " << (*it).second[k]);
00091       //       }
00092     }
00093
00094     {
00095       typename map<int,vector<Ref> >::iterator it = sent_byproc.begin();
00096       typename map<int,vector<Ref> >::iterator last = sent_byproc.end();
00097
00098       for(it = sent_byproc.begin();it != last;++it){
00099         DUMP((*it).second.size() << " atoms sent to proc " << (*it).first,DBG_INFO);
00100 //      for (unsigned int k = 0 ; k < (*it).second.size() ; ++k){
00101 //        LOG("sent atom " << (*it).second[k]);
00102 //      }
00103
00104       }
00105     }
00106
00107     {
00108
00109       std::map<int,int> temp;
00110       {
00111         typename map<Ref,int,typename Ref::RefComparator>::iterator it = sent.begin();
00112         typename map<Ref,int,typename Ref::RefComparator>::iterator last = sent.end();
00113
00114         for(it = sent.begin();it != last;++it){
00115           ++temp[(*it).second];
00116         }
00117       }
00118 //       {
00119 //      typename map<int,vector<Ref> >::iterator it = sent_byproc.begin();
00120 //      typename map<int,vector<Ref> >::iterator last = sent_byproc.end();
00121
00122 //      for(it = sent_byproc.begin();it != last;++it){
00123 //        if((*it).second.size() != temp[(*it).first])
00124 //          FATAL("sent_by_proc registered " <<  (*it).second.size()
00125 //                << " atoms as sended but sent registered " << temp[(*it).first]
00126 //                << " fatal inconstistency in send maps");
00127 //      }
00128 //       }
00129
00130
00131     }
00132
00133
00134
00135   }
00136
00137   MPI_Barrier(worldCom);
00138
00139   //construit les masques d'appartenances des atomes a des sous ensembles
00140   DUMP("analyse ref subset",DBG_WARNING);
00141   AnalyseSubSets();
00142   DUMP("analyse of ref subset done",DBG_WARNING);
00143   MPI_Barrier(worldCom);
00144   //fait s'échanger les masques d'appartenances au sous groupes
00145   DUMP("exchange subset masks",DBG_WARNING);
00146   ExchangeSubSetsMasks();
00147   PrintBilanToScreen();
00148   DUMP("exchange subset masks done",DBG_WARNING);
00149   MPI_Barrier(worldCom);
00150   //effectue le transfert des valeurs des vecteurs attachés
00151   DUMP("exchange subset attached values",DBG_WARNING);
00152   ExchangeSubSetAttachedValues();
00153   DUMP("exchange subset attached values done",DBG_WARNING);
00154   MPI_Barrier(worldCom);
00155   //effectue la creation des nouvelles references dans les subsets
00156   DUMP("exchange atoms in subsets",DBG_WARNING);
00157   CreationExchangedAtomsInSubSets();
00158   DUMP("exchange atoms in subsets done",DBG_WARNING);
00159   MPI_Barrier(worldCom);
00160 #ifdef DEBUG_REFERENCEMANAGER
00161   DUMP("check subsets cardinal",DBG_WARNING);
00162   //fait une verification que le cardinal des subsets gere n'ont pas changer avec la migration
00163   CheckSubSetsCardinal();
00164   DUMP("check subsets cardinal done",DBG_WARNING);
00165 #endif
00166   //vide toutes les structures pour la prochaine fois
00167   DUMP("clear STL",DBG_WARNING);
00168   ClearSTL();
00169   DUMP("clear STL done",DBG_WARNING);
00170
00171   have_changed = false;
00172   DUMP("end update ref",DBG_INFO);
00173 }
Member Data Documentation
std::map<int,std::vector<void *> > ReferenceManager< Ref >::attached_duo [protected]
Definition at line 130 of file reference_manager.h.
Referenced by ReferenceManager< Ref >::AdjustSizeRecvBuffers(), ReferenceManager< Ref >::AttachDuoDistributedVector(), ReferenceManager< Ref >::BuildSendingBuffers(), ReferenceManager< Ref >::CreationExchangedAtomsInSubSets(), and ReferenceManager< Ref >::DecodeBuffers().
std::map<Ref,std::map<int,std::vector<double> >,typename Ref::RefComparator> ReferenceManager< Ref >::attached_values [protected]
Definition at line 128 of file reference_manager.h.
Referenced by ReferenceManager< Ref >::ClearSTL(), ReferenceManager< Ref >::CreationExchangedAtomsInSubSets(), and ReferenceManager< Ref >::DecodeBuffers().
std::map<Ref,std::map<int,std::vector<int> >,typename Ref::RefComparator> ReferenceManager< Ref >::attached_values_duo [protected]
Definition at line 132 of file reference_manager.h.
std::map<int,std::vector<double *> > ReferenceManager< Ref >::attached_vectors [protected]
Definition at line 126 of file reference_manager.h.
Referenced by ReferenceManager< Ref >::AdjustSizeRecvBuffers(), ReferenceManager< Ref >::AttachVector(), ReferenceManager< Ref >::BuildSendingBuffers(), ReferenceManager< Ref >::CreationExchangedAtomsInSubSets(), and ReferenceManager< Ref >::DecodeBuffers().
std::map<Ref,int,typename Ref::RefComparator> ReferenceManager< Ref >::concerned_conteneurs_recv [protected]
Definition at line 120 of file reference_manager.h.
Referenced by ReferenceManager< Ref >::AdjustSizeRecvBuffers(), ReferenceManager< Ref >::ClearSTL(), ReferenceManager< Ref >::CreationExchangedAtomsInSubSets(), ReferenceManager< Ref >::DecodeBuffers(), ReferenceManager< Ref >::ExchangeSubSetsMasks(), and ReferenceManager< Ref >::PrintBilanToScreen().
std::map<Ref,int,typename Ref::RefComparator> ReferenceManager< Ref >::concerned_conteneurs_sent [protected]
Definition at line 118 of file reference_manager.h.
Referenced by ReferenceManager< Ref >::AnalyseSubSets(), ReferenceManager< Ref >::BuildSendingBuffers(), ReferenceManager< Ref >::ClearSTL(), ReferenceManager< Ref >::ExchangeSubSetsMasks(), and ReferenceManager< Ref >::PrintBilanToScreen().
std::vector<ContenerTableauRefAtome<Ref> *> ReferenceManager< Ref >::conteneurs [protected]
Definition at line 116 of file reference_manager.h.
Referenced by ReferenceManager< Ref >::AdjustSizeRecvBuffers(), ReferenceManager< Ref >::AnalyseSubSets(), ReferenceManager< Ref >::AttachDuoDistributedVector(), ReferenceManager< Ref >::AttachVector(), ReferenceManager< Ref >::BuildSendingBuffers(), ReferenceManager< Ref >::CheckSubSetsCardinal(), ReferenceManager< Ref >::CreationExchangedAtomsInSubSets(), ReferenceManager< Ref >::DecodeBuffers(), ReferenceManager< Ref >::PrintBilanToScreen(), ReferenceManager< RefLammps >::RequestCreationSubSet(), and ReferenceManager< RefLammps >::~ReferenceManager().
bool ReferenceManager< Ref >::have_changed [protected]
Definition at line 113 of file reference_manager.h.
std::map<Ref,Ref,typename Ref::RefComparator> ReferenceManager< Ref >::moved [protected]
Definition at line 135 of file reference_manager.h.
Referenced by ReferenceManager< Ref >::AnalyseSubSets(), ReferenceManager< Ref >::ClearSTL(), and ReferenceManager< Ref >::UpdateRefSubSets().
std::map<int,std::vector<Ref> > ReferenceManager< Ref >::newatoms [protected]
Definition at line 143 of file reference_manager.h.
Referenced by ReferenceManager< Ref >::AdjustSizeRecvBuffers(), ReferenceManager< Ref >::ClearSTL(), ReferenceManager< Ref >::DecodeBuffers(), ReferenceManager< Ref >::ExchangeSubSetAttachedValues(), ReferenceManager< Ref >::ExchangeSubSetsMasks(), and ReferenceManager< Ref >::UpdateRefSubSets().
int ReferenceManager< Ref >::rank [protected]
Definition at line 147 of file reference_manager.h.
Referenced by ReferenceManager< Ref >::ExchangeSubSetAttachedValues(), ReferenceManager< Ref >::ExchangeSubSetsMasks(), and ReferenceManager< RefLammps >::ReferenceManager().
std::map<Ref,int,typename Ref::RefComparator> ReferenceManager< Ref >::sent [protected]
Definition at line 138 of file reference_manager.h.
std::map<int,std::vector<Ref> > ReferenceManager< Ref >::sent_byproc [protected]
Definition at line 140 of file reference_manager.h.
Referenced by ReferenceManager< Ref >::BuildSendingBuffers(), ReferenceManager< Ref >::ClearSTL(), ReferenceManager< Ref >::ExchangeSubSetAttachedValues(), ReferenceManager< Ref >::ExchangeSubSetsMasks(), and ReferenceManager< Ref >::UpdateRefSubSets().
std::vector<std::map<Ref,int,typename Ref::RefComparator> > ReferenceManager< Ref >::trous [protected]
Definition at line 122 of file reference_manager.h.
Referenced by ReferenceManager< Ref >::AnalyseSubSets(), ReferenceManager< Ref >::BuildSendingBuffers(), ReferenceManager< Ref >::ClearSTL(), and ReferenceManager< Ref >::CreationExchangedAtomsInSubSets().
MPI_Comm ReferenceManager< Ref >::worldCom [protected]
Definition at line 146 of file reference_manager.h.
Referenced by ReferenceManager< Ref >::AnalyseSubSets(), ReferenceManager< Ref >::CheckSubSetsCardinal(), ReferenceManager< Ref >::ExchangeSubSetAttachedValues(), ReferenceManager< Ref >::ExchangeSubSetsMasks(), ReferenceManager< RefLammps >::ReferenceManager(), and ReferenceManager< Ref >::UpdateRefSubSets().
The documentation for this class was generated from the following files:
Generated on Fri Sep 7 13:13:27 2007 for LibMultiScale by  doxygen 1.5.2
