#include <xml_parser_elast.h>
Inheritance diagram for XMLElasticityParser:
Public Member Functions | |
| virtual int | ParseFile (char *name) |
| XMLElasticityParser (DOFLibMesh &d, GhostedNumericVector< Number > &a) | |
Protected Member Functions | |
| void | charHandler (const XML_Char *str, int len) |
| void | endElement (const char *name) |
| void | startElement (const char *name, const char **atts) |
Private Member Functions | |
| void | manageA (char *s) |
| void | manageMassMatrixX (char *s) |
| void | manageMassMatrixY (char *s) |
| void | manageMassMatrixZ (char *s) |
| void | manageNodeIDs (char *s) |
| void | manageP0 (char *s) |
| void | manageU (char *s) |
| void | manageV (char *s) |
Private Attributes | |
| GhostedNumericVector< Number > & | A |
| unsigned int | cpt |
| int | current_field |
| unsigned int | Dim |
| DOFLibMesh & | dofs |
| unsigned int | nbNodes |
| int * | tab_indexes |
Definition at line 52 of file xml_parser_elast.h.
| XMLElasticityParser::XMLElasticityParser | ( | DOFLibMesh & | d, | |
| GhostedNumericVector< Number > & | a | |||
| ) | [inline] |
| void XMLElasticityParser::charHandler | ( | const XML_Char * | str, | |
| int | len | |||
| ) | [inline, protected, virtual] |
Implements XMLParser.
Definition at line 75 of file xml_parser_elast.h.
References ACC, XMLParser::buf, current_field, DEP, IDS, manageA(), manageNodeIDs(), manageP0(), manageU(), manageV(), P0S, and VEL.
00075 { 00076 char buf[512]; 00077 00078 00079 if (len == 0) 00080 return; 00081 00082 strncpy(buf,str,len); 00083 buf[len]='\0'; 00084 00085 if (buf[0] == '\n') 00086 return; 00087 00088 // DUMP("len = " << len); 00089 //DUMP("buf = " << buf); 00090 00091 switch (current_field){ 00092 case IDS: manageNodeIDs(buf);break; 00093 case P0S: manageP0(buf);break; 00094 case DEP: manageU(buf);break; 00095 case VEL: manageV(buf);break; 00096 case ACC: manageA(buf);break; 00097 } 00098 };
Here is the call graph for this function:
| void XMLElasticityParser::endElement | ( | const char * | name | ) | [inline, protected, virtual] |
Definition at line 135 of file xml_parser_elast.h.
References ACC, cpt, current_field, DEP, FATAL, IDS, nbNodes, P0S, and VEL.
00135 { 00136 00137 char message[256]; 00138 00139 switch (current_field){ 00140 case IDS: sprintf(message,"%s : in vector IDs ",name);break; 00141 case P0S: sprintf(message,"%s : in vector P0s ",name);break; 00142 case DEP: sprintf(message,"%s : in vector Us ",name);break; 00143 case VEL: sprintf(message,"%s : in vector Vs ",name);break; 00144 case ACC: sprintf(message,"%s : in vector As ",name);break; 00145 } 00146 current_field = NOONE; 00147 00148 if (cpt != 0 && cpt != nbNodes) 00149 FATAL(message << ": values number do not concord (read " << cpt << " should be " << nbNodes << ")"); 00150 };
| void XMLElasticityParser::manageA | ( | char * | s | ) | [inline, private] |
Definition at line 279 of file xml_parser_elast.h.
References A, cpt, DBG_ALL, Dim, DUMP, and tab_indexes.
Referenced by charHandler().
00279 { 00280 double ax=0,ay=0,az=0; 00281 double tmp; 00282 00283 std::istringstream str(s); 00284 00285 int start = A.first_local_index(); 00286 int last = A.last_local_index(); 00287 00288 while (str >> tmp){ 00289 00290 int index = tab_indexes[cpt]*Dim; 00291 00292 ++cpt; 00293 00294 // DUMP("index = " << index); 00295 ax = tmp; 00296 if (Dim > 1 && str >> tmp) ay = tmp; 00297 if (Dim == 3 && str >> tmp) az = tmp; 00298 00299 if (index < start || index >= last) 00300 continue; 00301 00302 A.set(index,ax); 00303 if (Dim > 1 ) 00304 A.set(index+1,ay); 00305 if (Dim == 3) 00306 A.set(index+2,az); 00307 00308 DUMP(ax << " " << ay << " " << az,DBG_ALL); 00309 00310 } 00311 00312 A.close(); 00313 };
| void XMLElasticityParser::manageMassMatrixX | ( | char * | s | ) | [inline, private] |
| void XMLElasticityParser::manageMassMatrixY | ( | char * | s | ) | [inline, private] |
| void XMLElasticityParser::manageMassMatrixZ | ( | char * | s | ) | [inline, private] |
| void XMLElasticityParser::manageNodeIDs | ( | char * | s | ) | [inline, private] |
Definition at line 155 of file xml_parser_elast.h.
References cpt, and tab_indexes.
00155 { 00156 int id; 00157 00158 00159 std::istringstream str(s); 00160 00161 while (str >> id){ 00162 tab_indexes[cpt] = id; 00163 ++cpt; 00164 // DUMP(id); 00165 } 00166 00167 };
| void XMLElasticityParser::manageP0 | ( | char * | s | ) | [inline, private] |
Definition at line 168 of file xml_parser_elast.h.
References cpt, DBG_ALL, Dim, dofs, DUMP, DOFLibMesh::P0(), and tab_indexes.
00168 { 00169 double x=0,y=0,z=0; 00170 double xold=0,yold=0,zold=0; 00171 char tmp[256]; 00172 00173 std::istringstream str(s); 00174 00175 GhostedNumericVector<Number> & P0 = dofs.P0(); 00176 int start = P0.first_local_index(); 00177 int last = P0.last_local_index(); 00178 00179 while (str >> tmp){ 00180 00181 int index = tab_indexes[cpt]*Dim; 00182 ++cpt; 00183 00184 // DUMP("index = " << index); 00185 xold = atof(tmp); 00186 if (Dim > 1 && str >> tmp) yold = atof(tmp); 00187 if (Dim == 3 && str >> tmp) zold = atof(tmp); 00188 00189 if (index < start || index >= last) continue; 00190 00191 x = P0[index]; 00192 if (Dim > 1) 00193 y = P0[index+1]; 00194 if (Dim == 3) 00195 z = P0[index+2]; 00196 00197 DUMP(x << " " << y << " " << z << " " << xold << " " << yold << " " << zold,DBG_ALL); 00198 00199 /* if (ipow(x - xold,2) + ipow(y - yold,2) + ipow(z - zold,2) > ) */ 00200 /* FATAL("there seems to have a trouble beetween restart file and loaded simulation (are they equivalent ?)"); */ 00201 00202 } 00203 00204 };
| void XMLElasticityParser::manageU | ( | char * | s | ) | [inline, private] |
Definition at line 205 of file xml_parser_elast.h.
References cpt, DBG_ALL, Dim, dofs, DUMP, tab_indexes, and DOFLibMesh::U().
00205 { 00206 double ux=0,uy=0,uz=0; 00207 double tmp; 00208 00209 std::istringstream str(s); 00210 00211 GhostedNumericVector<Number> & U = dofs.U(); 00212 int start = U.first_local_index(); 00213 int last = U.last_local_index(); 00214 00215 while (str >> tmp){ 00216 00217 int index = tab_indexes[cpt]*Dim; 00218 00219 ++cpt; 00220 00221 // DUMP("index = " << index); 00222 ux = tmp; 00223 if (Dim > 1 && str >> tmp) uy = tmp; 00224 if (Dim == 3 && str >> tmp) uz = tmp; 00225 00226 if (index < start || index >= last) 00227 continue; 00228 00229 U.set(index,ux); 00230 if (Dim > 1) 00231 U.set(index+1,uy); 00232 if (Dim == 3) 00233 U.set(index+2,uz); 00234 00235 00236 DUMP(ux << " " << uy << " " << uz,DBG_ALL); 00237 00238 } 00239 00240 U.close(); 00241 };
| void XMLElasticityParser::manageV | ( | char * | s | ) | [inline, private] |
Definition at line 242 of file xml_parser_elast.h.
References cpt, DBG_ALL, Dim, dofs, DUMP, tab_indexes, and DOFLibMesh::V().
00242 { 00243 double vx=0,vy=0,vz=0; 00244 double tmp; 00245 00246 std::istringstream str(s); 00247 00248 GhostedNumericVector<Number> & V = dofs.V(); 00249 int start = V.first_local_index(); 00250 int last = V.last_local_index(); 00251 00252 while (str >> tmp){ 00253 00254 int index = tab_indexes[cpt]*Dim; 00255 00256 DUMP("index = " << index,DBG_ALL); 00257 00258 ++cpt; 00259 00260 vx = tmp; 00261 if (Dim > 1 && str >> tmp) vy = tmp; 00262 if (Dim == 3 && str >> tmp) vz = tmp; 00263 00264 if (index < start || index >= last) 00265 continue; 00266 00267 V.set(index,vx); 00268 if (Dim > 1 ) 00269 V.set(index+1,vy); 00270 if (Dim == 3) 00271 V.set(index+2,vz); 00272 00273 DUMP("setting v[" << index/Dim << "]" << vx << " " << vy << " " << vz,DBG_ALL); 00274 00275 } 00276 00277 V.close(); 00278 };
| virtual int XMLElasticityParser::ParseFile | ( | char * | name | ) | [inline, virtual] |
Definition at line 59 of file xml_parser_elast.h.
References DBG_INFO, Dim, DUMP, nbNodes, and XMLParser::ParseFile().
00059 { 00060 XMLParser::ParseFile(name); 00061 00062 DUMP("dimension read : " << Dim,DBG_INFO); 00063 DUMP("nbNodes read : " << nbNodes,DBG_INFO); 00064 00065 /* for (unsigned int i = 0 ; i < nbNodes ; ++i){ */ 00066 /* std::cout << tab_indexes[i] << " "; */ 00067 /* } */ 00068 /* std::cout << std::endl; */ 00069 return 0; 00070 }
| void XMLElasticityParser::startElement | ( | const char * | name, | |
| const char ** | atts | |||
Definition at line 100 of file xml_parser_elast.h.
References ACC, cpt, current_field, Dim, IDS, nbNodes, P0S, tab_indexes, and VEL.
00100 { 00101 int j; 00102 cpt=0; 00103 00104 if (strcmp("meshData",name)==0){ 00105 for (j=0; (j < 10 && atts[j] != NULL);++j){ 00106 if (strcmp("dim",atts[j])==0){ 00107 Dim = atoi(atts[j+1]); 00108 // printf("Dim = %d\n",data.Dim); 00109 ++j; 00110 } 00111 if (strcmp("nbNodes",atts[j])==0){ 00112 nbNodes = atoi(atts[j+1]); 00113 //printf("nbNodes = %d\n",data.nbNodes); 00114 ++j; 00115 tab_indexes = new int[nbNodes]; 00116 } 00117 } 00118 } 00119 if (strcmp("nodeIDs",name)==0){ 00120 current_field = IDS; 00121 } 00122 if (strcmp("P0",name)==0){ 00123 current_field = P0S; 00124 } 00125 if (strcmp("V",name)==0){ 00126 current_field = VEL; 00127 } 00128 if (strcmp("A",name)==0){ 00129 current_field = ACC; 00130 } 00131 00132 00133 };
GhostedNumericVector<Number>& XMLElasticityParser::A [private] |
unsigned int XMLElasticityParser::cpt [private] |
Definition at line 329 of file xml_parser_elast.h.
Referenced by endElement(), manageA(), manageNodeIDs(), manageP0(), manageU(), manageV(), and startElement().
int XMLElasticityParser::current_field [private] |
Definition at line 328 of file xml_parser_elast.h.
Referenced by charHandler(), endElement(), and startElement().
unsigned int XMLElasticityParser::Dim [private] |
Definition at line 322 of file xml_parser_elast.h.
Referenced by manageA(), manageP0(), manageU(), manageV(), ParseFile(), and startElement().
DOFLibMesh& XMLElasticityParser::dofs [private] |
Definition at line 331 of file xml_parser_elast.h.
Referenced by manageP0(), manageU(), and manageV().
unsigned int XMLElasticityParser::nbNodes [private] |
Definition at line 325 of file xml_parser_elast.h.
Referenced by endElement(), ParseFile(), and startElement().
int* XMLElasticityParser::tab_indexes [private] |
Definition at line 326 of file xml_parser_elast.h.
Referenced by manageA(), manageNodeIDs(), manageP0(), manageU(), manageV(), and startElement().
1.5.2
