#include <xml_parser_restart.h>
Inheritance diagram for XMLRestartParser:
Public Member Functions | |
| void | AssignDispField (double x, double y, double z, double &ux, double &uy, double &uz) |
| void | AssignForceField (double x, double y, double z, double &ux, double &uy, double &uz) |
| void | AssignVelField (double x, double y, double z, double &ux, double &uy, double &uz) |
| bool | IsDofRegistered (double x, double y, double z) |
| virtual int | ParseFile (const char *name) |
| XMLRestartParser () | |
Protected Member Functions | |
| void | charHandler (const XML_Char *str, int len) |
| void | endElement (const char *name) |
| void | startElement (const char *name, const char **atts) |
Private Member Functions | |
| void | manageA (char *s) |
| void | manageP0 (char *s) |
| void | manageU (char *s) |
| void | manageV (char *s) |
| int | readTriplet (Triplet &C, char *s) |
Private Attributes | |
| Base64Reader | b64 |
| helper for base64 | |
| unsigned int | cpt |
| int | current_field |
| unsigned int | Dim |
| std::map< Triplet, Triplet, ComparateurTriplet > | mapA |
| std::map< int, Triplet > | mapP0 |
| std::map< Triplet, Triplet, ComparateurTriplet > | mapU |
| std::map< Triplet, Triplet, ComparateurTriplet > | mapV |
| unsigned int | nbDofs |
| double | savedTime |
| int * | tab_indexes |
| Triplet | triplet |
| temporary triplet (for incomlete lines) | |
| int | type |
Definition at line 146 of file xml_parser_restart.h.
| XMLRestartParser::XMLRestartParser | ( | ) | [inline] |
| void XMLRestartParser::AssignDispField | ( | double | x, | |
| double | y, | |||
| double | z, | |||
| double & | ux, | |||
| double & | uy, | |||
| double & | uz | |||
Definition at line 310 of file xml_parser_restart.cpp.
References Dim, mapU, and Triplet::Truncate().
Referenced by DomainAtomic< C >::ReadXMLFile(), and DomainContinuum< ContenerElems, ContenerNodes, Dim >::ReadXMLFile().
00310 { 00311 if (Dim < 3) z = 0; 00312 if (Dim == 1) y = 0; 00313 Triplet a(x,y,z); 00314 a.Truncate(); 00315 Triplet &b = mapU[a]; 00316 ux = b(0); 00317 uy = b(1); 00318 uz = b(2); 00319 };
Here is the call graph for this function:
| void XMLRestartParser::AssignForceField | ( | double | x, | |
| double | y, | |||
| double | z, | |||
| double & | uz | |||
Definition at line 332 of file xml_parser_restart.cpp.
References Dim, mapA, and Triplet::Truncate().
00332 { 00333 if (Dim < 3) z = 0; 00334 if (Dim == 1) y = 0; 00335 Triplet a(x,y,z); 00336 a.Truncate(); 00337 Triplet &b = mapA[a]; 00338 ux = b(0); 00339 uy = b(1); 00340 uz = b(2); 00341 };
| void XMLRestartParser::AssignVelField | ( | double | x, | |
| double | y, | |||
| double | z, | |||
| double & | uz | |||
Definition at line 321 of file xml_parser_restart.cpp.
References Dim, mapV, and Triplet::Truncate().
00321 { 00322 if (Dim < 3) z = 0; 00323 if (Dim == 1) y = 0; 00324 Triplet a(x,y,z); 00325 a.Truncate(); 00326 Triplet &b = mapV[a]; 00327 ux = b(0); 00328 uy = b(1); 00329 uz = b(2); 00330 };
| void XMLRestartParser::charHandler | ( | const XML_Char * | str, | |
| int | len | |||
| ) | [protected, virtual] |
Implements XMLParser.
Definition at line 91 of file xml_parser_restart.cpp.
References ACC, b64, XMLParser::buf, current_field, DBG_ALL, DEP, DUMP, manageA(), manageP0(), manageU(), manageV(), P0S, Base64Reader::SetStream(), TEXT, type, and VEL.
00091 { 00092 char * buf; 00093 00094 DUMP("read a line of size " << len,DBG_ALL); 00095 if (len == 0) 00096 return; 00097 00098 buf = new char[len+1]; 00099 00100 strncpy(buf,str,len); 00101 00102 if (type == TEXT) 00103 buf[len]='\0'; 00104 else 00105 b64.SetStream(buf,len); 00106 00107 if (buf[0] == '\n') 00108 return; 00109 00110 // DUMP("len = " << len); 00111 //DUMP("buf = " << buf); 00112 00113 switch (current_field){ 00114 case P0S: manageP0(buf);break; 00115 case DEP: manageU(buf);break; 00116 case VEL: manageV(buf);break; 00117 case ACC: manageA(buf);break; 00118 } 00119 00120 delete [] buf; 00121 };
| void XMLRestartParser::endElement | ( | const char * | name | ) | [protected, virtual] |
Definition at line 185 of file xml_parser_restart.cpp.
References ACC, cpt, current_field, DEP, FATAL, nbDofs, NONE, P0S, and VEL.
00185 { 00186 00187 char message[256]; 00188 00189 switch (current_field){ 00190 case P0S: sprintf(message,"%s : in vector P0s ",name);break; 00191 case DEP: sprintf(message,"%s : in vector Us ",name);break; 00192 case VEL: sprintf(message,"%s : in vector Vs ",name);break; 00193 case ACC: sprintf(message,"%s : in vector As ",name);break; 00194 } 00195 current_field = NONE; 00196 00197 if (cpt != 0 && cpt != nbDofs) 00198 FATAL(message << ": values number do not concord (read " << cpt << " should be " << nbDofs << ")"); 00199 };
| bool XMLRestartParser::IsDofRegistered | ( | double | x, | |
| double | y, | |||
| double | z | |||
Definition at line 277 of file xml_parser_restart.cpp.
References DBG_ALL, Dim, DUMP, FORMATREAL, mapU, Triplet::Truncate(), Triplet::tx, Triplet::ty, and Triplet::tz.
00277 { 00278 double epsilon2 = .8e-10*.8e-10; 00279 00280 if (Dim < 3) z = 0; 00281 if (Dim == 1) y = 0; 00282 Triplet a(x,y,z); 00283 a.Truncate(); 00284 if (mapU.count(a) == 0) { 00285 std::map<Triplet,Triplet>::iterator pos; 00286 DUMP("testing if already registered with the position " << a,DBG_ALL); 00287 pos = find_if(mapU.begin(),mapU.end(),close_enough(a)); 00288 00289 if(pos != mapU.end()){ 00290 Triplet found = pos->first; 00291 double dx = a(0) - found(0); 00292 double dy = a(1) - found(1); 00293 double dz = a(2) - found(2); 00294 00295 double rmin = dx*dx + dy*dy +dz*dz; 00296 DUMP("minimal distance = " << FORMATREAL(rmin) << " " << found(0) << " " << found(1) << " " << found(2),DBG_ALL); 00297 if ( rmin > epsilon2 ) return false; 00298 Triplet::tx = found(0) - x;Triplet::ty=found(1) - y;Triplet::tz=found(2) -z; 00299 DUMP("translation " << FORMATREAL(Triplet::tx) << " " << Triplet::ty << " " << Triplet::tz,DBG_ALL); 00300 00301 return true; 00302 } 00303 DUMP("Triplet not found : " << a,DBG_ALL); 00304 return false; 00305 } 00306 return true; 00307 };
| void XMLRestartParser::manageA | ( | char * | s | ) | [private] |
Definition at line 267 of file xml_parser_restart.cpp.
References cpt, DBG_ALL, DUMP, mapA, mapP0, nbDofs, and readTriplet().
Referenced by charHandler().
00267 { 00268 Triplet a; 00269 while (readTriplet(a,s) && cpt < nbDofs){ 00270 mapA[mapP0[cpt]] = a; 00271 DUMP(a(0) << " + " << a(1) << " + " << a(2) << " + " << cpt,DBG_ALL); 00272 ++cpt; 00273 } 00274 };
| void XMLRestartParser::manageP0 | ( | char * | s | ) | [private] |
Definition at line 238 of file xml_parser_restart.cpp.
References cpt, DBG_ALL, DUMP, mapP0, nbDofs, readTriplet(), and Triplet::Truncate().
00238 { 00239 Triplet C; 00240 while (readTriplet(C,s) && cpt < nbDofs){ 00241 C.Truncate(); 00242 mapP0[cpt] = C; 00243 DUMP(C(0) << " " << C(1) << " " << C(2) << " " << cpt,DBG_ALL); 00244 ++cpt; 00245 } 00246 };
| void XMLRestartParser::manageU | ( | char * | s | ) | [private] |
Definition at line 249 of file xml_parser_restart.cpp.
References cpt, DBG_ALL, DUMP, mapP0, mapU, nbDofs, and readTriplet().
00249 { 00250 Triplet u; 00251 while (readTriplet(u,s) && cpt < nbDofs){ 00252 mapU[mapP0[cpt]] = u; 00253 DUMP(u(0) << " + " << u(1) << " + " << u(2) << " + " << cpt,DBG_ALL); 00254 ++cpt; 00255 } 00256 };
| void XMLRestartParser::manageV | ( | char * | s | ) | [private] |
Definition at line 258 of file xml_parser_restart.cpp.
References cpt, DBG_ALL, DUMP, mapP0, mapV, nbDofs, and readTriplet().
00258 { 00259 Triplet v; 00260 while (readTriplet(v,s) && cpt < nbDofs){ 00261 mapV[mapP0[cpt]] = v; 00262 DUMP(v(0) << " + " << v(1) << " + " << v(2) << " + " << cpt,DBG_ALL); 00263 ++cpt; 00264 } 00265 };
| virtual int XMLRestartParser::ParseFile | ( | const char * | name | ) | [inline, virtual] |
Reimplemented from XMLParser.
Definition at line 158 of file xml_parser_restart.h.
References XMLParser::ParseFile().
00158 { 00159 XMLParser::ParseFile(name); 00160 00161 return 0; 00162 }
| int XMLRestartParser::readTriplet | ( | Triplet & | C, | |
| char * | s | |||
| ) | [private] |
Definition at line 201 of file xml_parser_restart.cpp.
References b64, BINARY, DBG_ALL, DUMP, Triplet::getRead(), Base64Reader::PopDoubleInBase64(), TEXT, triplet, and type.
Referenced by manageA(), manageP0(), manageU(), and manageV().
00201 { 00202 if (type == TEXT){ 00203 std::istringstream str(s); 00204 char tmp[256]; 00205 if (triplet.getRead() == 0 && str >> tmp) { 00206 triplet(0) = atof(tmp); 00207 triplet.getRead()++; 00208 } 00209 else return 0; 00210 if (triplet.getRead() == 1 && str >> tmp) { 00211 triplet(1) = atof(tmp); 00212 triplet.getRead()++; 00213 } 00214 else return 0; 00215 if (triplet.getRead() == 2 && str >> tmp) { 00216 triplet(2) = atof(tmp); 00217 triplet.getRead()++; 00218 } 00219 else return 0; 00220 } 00221 00222 if (type == BINARY){ 00223 for (int i = triplet.getRead() ; i < 3 ; ++i){ 00224 DUMP("read " << triplet.getRead() << " " << i,DBG_ALL); 00225 triplet.getRead() += b64.PopDoubleInBase64(triplet(i)); 00226 DUMP("read " << triplet.getRead() << " " << i,DBG_ALL); 00227 if (i+1 != triplet.getRead()) {DUMP("already red " << triplet.getRead() << " components of the triplet",DBG_ALL);return 0;} 00228 } 00229 } 00230 00231 C = triplet; 00232 triplet.getRead() = 0; 00233 00234 return 1; 00235 }
| void XMLRestartParser::startElement | ( | const char * | name, | |
| const char ** | atts | |||
Definition at line 124 of file xml_parser_restart.cpp.
References ACC, BINARY, cpt, current_field, DBG_INFO, DEP, Dim, DUMP, nbDofs, P0S, savedTime, tab_indexes, TEXT, type, and VEL.
00124 { 00125 int j; 00126 cpt=0; 00127 00128 if (strcmp("SimulationData",name)==0){ 00129 for (j=0; (j < 10 && atts[j] != NULL);++j){ 00130 if (strcmp("dim",atts[j])==0){ 00131 Dim = atoi(atts[j+1]); 00132 //printf("Dim = %d\n",data.Dim); 00133 ++j; 00134 } 00135 /* if (strcmp("Unity",atts[j])==0){ */ 00136 /* if (strcmp("Real",atts[j+1])==0){ */ 00137 /* unit.SetReadUnits(UnitsConverter::AtomsUnits); */ 00138 /* } */ 00139 /* else if (strcmp("Atoms",atts[j+1])==0){ */ 00140 00141 /* } */ 00142 /* ++j; */ 00143 /* } */ 00144 if (strcmp("dataType",atts[j])==0){ 00145 if (strcmp("TEXT",atts[j+1])==0){ 00146 type = TEXT; 00147 } 00148 else type = BINARY; 00149 ++j; 00150 } 00151 if (strcmp("nbDofs",atts[j])==0){ 00152 nbDofs = atoi(atts[j+1]); 00153 //printf("nbNodes = %d\n",data.nbNodes); 00154 ++j; 00155 tab_indexes = new int[nbDofs]; 00156 } 00157 if (strcmp("savedTime",atts[j])==0){ 00158 savedTime = atoi(atts[j+1]); 00159 //printf("nbNodes = %d\n",data.nbNodes); 00160 ++j; 00161 } 00162 } 00163 } 00164 if (strcmp("P0",name)==0){ 00165 current_field = P0S; 00166 DUMP("reading intial positions",DBG_INFO); 00167 } 00168 if (strcmp("U",name)==0){ 00169 current_field = DEP; 00170 DUMP("reading displacements",DBG_INFO); 00171 } 00172 if (strcmp("V",name)==0){ 00173 current_field = VEL; 00174 DUMP("reading velocities",DBG_INFO); 00175 } 00176 if (strcmp("A",name)==0){ 00177 current_field = ACC; 00178 DUMP("reading accelerations",DBG_INFO); 00179 } 00180 00181 00182 };
Base64Reader XMLRestartParser::b64 [private] |
helper for base64
Definition at line 196 of file xml_parser_restart.h.
Referenced by charHandler(), and readTriplet().
unsigned int XMLRestartParser::cpt [private] |
Definition at line 192 of file xml_parser_restart.h.
Referenced by endElement(), manageA(), manageP0(), manageU(), manageV(), startElement(), and XMLRestartParser().
int XMLRestartParser::current_field [private] |
Definition at line 191 of file xml_parser_restart.h.
Referenced by charHandler(), endElement(), and startElement().
unsigned int XMLRestartParser::Dim [private] |
Definition at line 186 of file xml_parser_restart.h.
Referenced by AssignDispField(), AssignForceField(), AssignVelField(), IsDofRegistered(), startElement(), and XMLRestartParser().
std::map<Triplet,Triplet,ComparateurTriplet> XMLRestartParser::mapA [private] |
Definition at line 201 of file xml_parser_restart.h.
Referenced by AssignForceField(), and manageA().
std::map<int,Triplet> XMLRestartParser::mapP0 [private] |
Definition at line 202 of file xml_parser_restart.h.
std::map<Triplet,Triplet,ComparateurTriplet> XMLRestartParser::mapU [private] |
Definition at line 199 of file xml_parser_restart.h.
Referenced by AssignDispField(), IsDofRegistered(), and manageU().
std::map<Triplet,Triplet,ComparateurTriplet> XMLRestartParser::mapV [private] |
unsigned int XMLRestartParser::nbDofs [private] |
Definition at line 187 of file xml_parser_restart.h.
double XMLRestartParser::savedTime [private] |
Definition at line 188 of file xml_parser_restart.h.
Referenced by startElement(), and XMLRestartParser().
int* XMLRestartParser::tab_indexes [private] |
Triplet XMLRestartParser::triplet [private] |
Definition at line 184 of file xml_parser_restart.h.
Referenced by readTriplet().
int XMLRestartParser::type [private] |
Definition at line 193 of file xml_parser_restart.h.
Referenced by charHandler(), readTriplet(), and startElement().
1.5.2
