lennard_jones.h
Go to the documentation of this file.
00001 /* ./continuum/libmesh/lennard_jones.h
00002 **********************************
00003 Copyright INRIA and CEA
00004
00005 author : Guillaume ANCIAUX (anciaux@labri.fr, g.anciaux@laposte.net)
00006
00007 The LibMultiScale is a C++ parallel framework for the multiscale
00008 coupling methods dedicated to material simulations. This framework
00009 provides an API which makes it possible to program coupled simulations
00010 and integration of already existing codes.
00011
00012 This Project is done in a collaboration between INRIA Futurs Bordeaux
00013 within ScAlApplix team and CEA/DPTA Ile de France.
00014
00015 This software is governed by the CeCILL-C license under French law and
00016 abiding by the rules of distribution of free software.  You can  use,
00017 modify and/ or redistribute the software under the terms of the CeCILL-C
00018 license as circulated by CEA, CNRS and INRIA at the following URL
00019 "http://www.cecill.info".
00020
00021 As a counterpart to the access to the source code and  rights to copy,
00022 modify and redistribute granted by the license, users are provided only
00023 with a limited warranty  and the software's author,  the holder of the
00024 economic rights,  and the successive licensors  have only  limited
00025 liability.
00026
00027 In this respect, the user's attention is drawn to the risks associated
00028 with loading,  using,  modifying and/or developing or reproducing the
00029 software by the user in light of its specific status of free software,
00030 that may mean  that it is complicated to manipulate,  and  that  also
00031 therefore means  that it is reserved for developers  and  experienced
00032 professionals having in-depth computer knowledge. Users are therefore
00033 encouraged to load and test the software's suitability as regards their
00034 requirements in conditions enabling the security of their systems and/or
00035 data to be ensured and,  more generally, to use and operate it in the
00036 same conditions as regards security.
00037
00038 The fact that you are presently reading this means that you have had
00039 knowledge of the CeCILL-C license and that you accept its terms.
00040 ***********************************/
00041
00042 #ifndef LENNARDJONES
00043 #define LENNARDJONES
00044
00049 class LennardJones : public Potential<LennardJones>
00050 {
00051  public:
00052
00053   LennardJones(double _epsilon, double _sigma){
00054     epsilon =  _epsilon;
00055     sigma = _sigma;
00056
00057     DUMP("setting lennard jones parameters : sigma = " << FORMATREAL(sigma)
00058         << " , epsilon = " << FORMATREAL(epsilon),DBG_INFO_STARTUP);
00059   };
00060   ~LennardJones(){};
00061
00063   double ComputeForceFoisR(double inv_rr2){
00064     //    double rr2 = r*r;
00065     double rri2 = sigma*sigma * inv_rr2;
00066     double rri6 = rri2 * rri2 * rri2;
00067     DUMP("Computing force for inv_rr2=" << inv_rr2 << " : " << 24*epsilon*rri6*(1. - 2. * rri6),DBG_ALL);
00068     return 24*epsilon*rri6*(1. - 2. * rri6);
00069     }
00070
00072   double ComputeForce(double r){
00073     double rr2 = r*r;
00074     double rri2 = sigma*sigma / rr2;
00075     double rri6 = rri2 * rri2 * rri2;
00076     DUMP("Computing force for r= " << r << " : " << 24*epsilon*rri6*(1. - 2. * rri6)/r,DBG_ALL);
00077     return 24*epsilon*rri6*(1. - 2. * rri6)/r;
00078     }
00079
00080
00081  private:
00083   double epsilon;
00085   double sigma;
00086 };
00087
00088 #endif
Generated on Fri Sep 7 13:12:34 2007 for LibMultiScale by  doxygen 1.5.2
