00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031
00032
00033
00034
00035
00036
00037
00038
00039
00040
00041
00042 #define NEED_STAMP
00043 #define NEED_LAMMPS
00044 #define NEED_LIBMESH
00045 #define NEED_MD1D
00046
00047 #define ORDRE LINEAR
00048 #define LOCAL_MODULE MOD_COUPLING
00049
00050 template <typename DomainA, typename DomainC,unsigned int Dim>
00051 void MyMethodFull<DomainA,DomainC,Dim>::Init(){
00052
00053 DUMP("Computing freedom degrees weight",DBG_INFO);
00054 Parent::BuildAtomsWeight();
00055 Parent::BuildContinuWeight();
00056
00057 Parent::BuildPositions();
00058 Parent::BuildShapeMatrix(Parent::positions,Parent::atomes_rec.nbElem());
00059 delete [] Parent::positions;
00060
00061 Parent::BuildFictifsPositions();
00062 BuildShapeMatrixFictifs(Parent::positions,Parent::atomes_fictifs.nbElem());
00063 delete [] Parent::positions;
00064
00065 Parent::CorrectSurfaceEffect();
00066
00067 unsigned int taille = Parent::atomes_rec.nbElem();
00068 dist = new double[taille];
00069 orig_FE = new double[taille];
00070 orig_atom = new double[taille];
00071
00072 DUMP("Allocating matrix (" << taille << ")",DBG_INFO);
00073 A = new FullMatrix(taille,taille);
00074
00075 lagrange2 = new double[taille];
00076
00077
00078 DUMP("Allocating vector",DBG_INFO);
00079 rhs = new Vector(taille);
00080 rhs->zero();
00081 A->zero();
00082
00083
00084 DUMP("BuildConstraintMatrices",DBG_INFO);
00085 BuildConstraintMatrix();
00086 DUMP("Init done",DBG_INFO);
00087 }
00088
00089 template <typename DomainA, typename DomainC,unsigned int Dim>
00090 void MyMethodFull<DomainA,DomainC,Dim>::Stucking(){
00091
00092
00093
00094
00095 STARTTIMER("Correct Surface Effect");
00096 Parent::CorrectSurfaceEffect();
00097 STOPTIMER("Correct Surface Effect");
00098
00099 STARTTIMER();
00100 BuildRHS();
00101 STOPTIMER("BuildRHS");
00102
00103 STARTTIMER();
00104 SolveConstraint();
00105 STOPTIMER("Solving constraint");
00106
00107 STARTTIMER();
00108 ApplyCorrection();
00109 STOPTIMER("Correcting");
00110
00111
00112 }
00113
00114 template <typename DomainA, typename DomainC,unsigned int Dim>
00115 void MyMethodFull<DomainA,DomainC,Dim>::BuildConstraintMatrix(){
00116
00117
00118
00119
00120
00121
00122
00123
00124
00125
00126
00127
00128
00129
00130
00131
00132
00133
00134 MechaContLibMesh<Dim> & model = static_cast<MechaContLibMesh<Dim>&>(Parent::domC.getModel());
00135 double xI,xJ;
00136 std::vector<unsigned int> nodesI;
00137 std::vector<unsigned int> nodesJ;
00138 std::vector<double> shapesI;
00139 std::vector<double> shapesJ;
00140
00141 A->zero();
00142
00143 int taille = Parent::atomes_rec.nbElem();
00144
00145 for (int i = 0; i < taille ; ++i)
00146 for (int j = 0; j < taille ; ++j){
00147
00148 xI = Parent::atomes_rec.Get(i).position0(0);
00149 xJ = Parent::atomes_rec.Get(j).position0(0);
00150
00151 model.GlobalIndexes(Parent::elems_rec.Get(Parent::assoc[i]),nodesI);
00152 model.GlobalIndexes(Parent::elems_rec.Get(Parent::assoc[j]),nodesJ);
00153
00154 model.ComputeShapes(Parent::elems_rec.Get(Parent::assoc[i]),shapesI,xI);
00155 model.ComputeShapes(Parent::elems_rec.Get(Parent::assoc[j]),shapesJ,xJ);
00156
00157 if (nodesI[0] == nodesJ[0]){
00158 (*A)(i,j) += shapesI[0]*shapesJ[0]/model.Mass(nodesI[0]);
00159
00160 }
00161
00162 if (nodesI[1] == nodesJ[1]){
00163 (*A)(i,j) += shapesI[1]*shapesJ[1]/model.Mass(nodesI[1]);
00164
00165 }
00166
00167 if (nodesI[0] == nodesJ[1]){
00168 (*A)(i,j) += shapesI[0]*shapesJ[1]/model.Mass(nodesI[0]);
00169
00170 }
00171
00172 if (nodesI[1] == nodesJ[0]){
00173 (*A)(i,j) += shapesI[1]*shapesJ[0]/model.Mass(nodesI[1]);
00174
00175 }
00176 }
00177
00178 A->PrintToFile("constraint_matrix.mat");
00179
00180 A->FactoLU();
00181 }
00182
00183 static std::ofstream out_rhs("rhs_matrix.mat");
00184 static std::ofstream out_dist("dist.plot");
00185
00186 template <typename DomainA, typename DomainC,unsigned int Dim>
00187 void MyMethodFull<DomainA,DomainC,Dim>::BuildRHS(){
00188
00189 std::vector<unsigned int> nodesI;
00190 std::vector<double> shapesI;
00191
00192 double xI;
00193 MechaContLibMesh<Dim> & model = static_cast<MechaContLibMesh<Dim>&>(Parent::domC.getModel());
00194 typename Parent::_Vec_ & v = Parent::domC.getDofs().V();
00195
00196 rhs->zero();
00197 int taille = Parent::atomes_rec.nbElem();
00198
00199 for (int i = 0 ; i < taille ; ++i){
00200 xI = Parent::atomes_rec.Get(i).position0(0);
00201
00202 model.GlobalIndexes(Parent::elems_rec.Get(Parent::assoc[i]),nodesI);
00203 model.ComputeShapes(Parent::elems_rec.Get(Parent::assoc[i]),shapesI,xI);
00204
00205 (*rhs)(i) = v(nodesI[0])*shapesI[0] + v(nodesI[1])*shapesI[1] - Parent::atomes_rec.Get(i).vitesse(0);
00206 lagrange2[i] = (*rhs)(i);
00207 (*rhs)(i) *= Parent::lambdasA[i];
00208
00209 dist[i] = (1-Parent::lambdasA[i])*(v(nodesI[0])*shapesI[0] + v(nodesI[1])*shapesI[1]) + Parent::lambdasA[i]*Parent::atomes_rec.Get(i).vitesse(0);
00210 orig_FE[i] = v(nodesI[0])*shapesI[0] + v(nodesI[1])*shapesI[1];
00211 orig_atom[i] = Parent::atomes_rec.Get(i).vitesse(0);
00212 }
00213
00214 for (int i=0; i<taille; ++i)
00215 {
00216 out_rhs << i+1 << "\t" << current_step << "\t" << lagrange2[i] << std::endl;
00217 }
00218 }
00219
00220 template <typename DomainA, typename DomainC,unsigned int Dim>
00221 void MyMethodFull<DomainA,DomainC,Dim>::SolveConstraint(){
00222 int taille = Parent::atomes_rec.nbElem();
00223
00224 for (int i=0; i<taille; ++i)
00225 {
00226 DUMP("rhs[" << i << "] = " << (*rhs)(i),DBG_ALL);
00227 }
00228
00229 A->Solve(rhs);
00230
00231 for (int i=0; i<taille; ++i)
00232 {
00233 DUMP("multL[" << i << "] = " << (*rhs)(i),DBG_ALL);
00234 }
00235 }
00236
00237
00238 template <typename DomainA, typename DomainC,unsigned int Dim>
00239 void MyMethodFull<DomainA,DomainC,Dim>::ApplyCorrection(){
00240
00241 double xI;
00242
00243 typename Parent::_Vec_ & v = Parent::domC.getDofs().V();
00244 std::vector<unsigned int> nodesI;
00245 std::vector<double> shapesI;
00246 MechaContLibMesh<Dim> & model = static_cast<MechaContLibMesh<Dim>&>(Parent::domC.getModel());
00247 int taille = Parent::atomes_rec.nbElem();
00248
00249 for (int i = 0 ; i < taille ; ++i)
00250 {
00251 xI = Parent::atomes_rec.Get(i).position0(0);
00252
00253 Parent::atomes_rec.Get(i).vitesse(0) += (1-Parent::lambdasA[i])*lagrange2[i];
00254
00255 model.GlobalIndexes(Parent::elems_rec.Get(Parent::assoc[i]),nodesI);
00256
00257 model.ComputeShapes(Parent::elems_rec.Get(Parent::assoc[i]),shapesI,xI);
00258 DUMP(xI << " node1 " << nodesI[0] << " nodes2 " << nodesI[1],DBG_ALL);
00259 DUMP("pour " << xI << " correction = " << -1.0*(*rhs)(i)*shapesI[0]/model.Mass(nodesI[0]) << " et " <<
00260 -1.0*(*rhs)(i)*shapesI[1]/model.Mass(nodesI[1]),DBG_ALL);
00261 v.add(nodesI[0],-1.0*(*rhs)(i)*shapesI[0]/model.Mass(nodesI[0]));
00262 v.add(nodesI[1],-1.0*(*rhs)(i)*shapesI[1]/model.Mass(nodesI[1]));
00263
00264
00265 }
00266
00267 v.close();
00268 for (int i = 0 ; i < taille ; ++i){
00269 xI = Parent::atomes_rec.Get(i).position0(0);
00270 model.GlobalIndexes(Parent::elems_rec.Get(Parent::assoc[i]),nodesI);
00271 model.ComputeShapes(Parent::elems_rec.Get(Parent::assoc[i]),shapesI,xI);
00272 double new_dist = (1-Parent::lambdasA[i])*(v(nodesI[0])*shapesI[0] + v(nodesI[1])*shapesI[1]) +
00273 Parent::lambdasA[i]*Parent::atomes_rec.Get(i).vitesse(0);
00274 double contrainte = v(nodesI[0])*shapesI[0] + v(nodesI[1])*shapesI[1] - Parent::atomes_rec.Get(i).vitesse(0);
00275 out_dist << current_step << "\t" << xI << "\t" << dist[i] << "\t" << new_dist << "\t" << orig_FE[i] << "\t" << orig_atom[i] << "\t" << Parent::atomes_rec.Get(i).vitesse(0) << "\t" << v(nodesI[0])*shapesI[0] + v(nodesI[1])*shapesI[1] << "\t" << (*rhs)(i) << "\t" << Parent::lambdasA[i]*lagrange2[i] << "\t" << contrainte << std::endl;
00276 }
00277
00278
00279
00280 }
00281
00282 #ifdef USING_STAMP
00283 template class MyMethodFull<DomainStamp,DomainLibMesh<1>,1>;
00284 template class MyMethodFull<DomainStamp,DomainLibMesh<2>,2>;
00285 #endif
00286 #ifdef USING_LAMMPS
00287 template class MyMethodFull<DomainLammps,DomainLibMesh<2>,2>;
00288 template class MyMethodFull<DomainLammps,DomainLibMesh<3>,3>;
00289 #endif
00290 template class MyMethodFull<DomainMD1D,DomainLibMesh<1>,1>;
