Myblocks_ Struct Reference
#include <duo_distributed_vector.h>
List of all members.
Public Attributes
unsigned int end
 last index of the block + 1
unsigned int start
 first index of the block
Detailed Description
structure of a block in the redistribution scheme
Definition at line 50 of file duo_distributed_vector.h.
Member Data Documentation
unsigned int Myblocks_::end
Definition at line 54 of file duo_distributed_vector.h.
Referenced by DuoDistributedVecteur::AddAtomInBlocks(), DuoDistributedVecteur::AddAtomInBlocksWithDistIndex(), DuoDistributedVecteur::compress(), DuoDistributedVecteur::isInBlock(), DuoDistributedVecteur::RemoveAtomFromBlocks(), and BridgingPar< DomainA, DomainC, Dim, Pond >::UnfragmentScheme().
unsigned int Myblocks_::start
Definition at line 52 of file duo_distributed_vector.h.
The documentation for this struct was generated from the following file:
Generated on Fri Sep 7 13:13:24 2007 for LibMultiScale by  doxygen 1.5.2
