vector.h
Go to the documentation of this file.
00001 /* ./math/vector.h
00002 **********************************
00003 Copyright INRIA and CEA
00004
00005 author : Guillaume ANCIAUX (anciaux@labri.fr, g.anciaux@laposte.net)
00006
00007 The LibMultiScale is a C++ parallel framework for the multiscale
00008 coupling methods dedicated to material simulations. This framework
00009 provides an API which makes it possible to program coupled simulations
00010 and integration of already existing codes.
00011
00012 This Project is done in a collaboration between INRIA Futurs Bordeaux
00013 within ScAlApplix team and CEA/DPTA Ile de France.
00014
00015 This software is governed by the CeCILL-C license under French law and
00016 abiding by the rules of distribution of free software.  You can  use,
00017 modify and/ or redistribute the software under the terms of the CeCILL-C
00018 license as circulated by CEA, CNRS and INRIA at the following URL
00019 "http://www.cecill.info".
00020
00021 As a counterpart to the access to the source code and  rights to copy,
00022 modify and redistribute granted by the license, users are provided only
00023 with a limited warranty  and the software's author,  the holder of the
00024 economic rights,  and the successive licensors  have only  limited
00025 liability.
00026
00027 In this respect, the user's attention is drawn to the risks associated
00028 with loading,  using,  modifying and/or developing or reproducing the
00029 software by the user in light of its specific status of free software,
00030 that may mean  that it is complicated to manipulate,  and  that  also
00031 therefore means  that it is reserved for developers  and  experienced
00032 professionals having in-depth computer knowledge. Users are therefore
00033 encouraged to load and test the software's suitability as regards their
00034 requirements in conditions enabling the security of their systems and/or
00035 data to be ensured and,  more generally, to use and operate it in the
00036 same conditions as regards security.
00037
00038 The fact that you are presently reading this means that you have had
00039 knowledge of the CeCILL-C license and that you accept its terms.
00040 ***********************************/
00041
00042 #ifndef VECTOR
00043 #define VECTOR
00044
00045 #include <string.h>
00046
00047
00048 extern "C" {
00049   int ScaleVector(double * vector,int taille,double alpha);
00050 }
00051
00052 class Vector
00053 {
00054  public:
00055
00056   Vector(int t){
00057     taille = t;
00058     vector = new double[t];
00059   };
00060
00061   ~Vector(){};
00062
00064   double& operator()(int i){
00065     return vector[i];
00066   };
00067
00069   int PrintToFile(char * f,int step=0){
00070     FILE * file = fopen(f,"wb+");
00071     PrintToFile(file,step);
00072     fclose(file);
00073
00074     return 0;
00075   }
00076
00078   int PrintToFile(FILE * f,int step=0){
00079
00080     for (int i=0;i< taille;++i)
00081       {
00082         fprintf(f,"%d\t%d\t%.15e\n",i,step,vector[i]);
00083       }
00084
00085     return 0;
00086   };
00087
00089   double * GetVector(){
00090     return vector;
00091   };
00092
00094   int zero(){
00095     memset(vector,0,taille*sizeof(double)); // mise a zero
00096     return 0;
00097   }
00098
00100   void Scale(double a){
00101     ScaleVector(vector,taille,a);
00102   }
00103
00104  protected:
00105
00107   int taille;
00109   double * vector;
00110
00111
00112 };
00113
00114 #endif
Generated on Fri Sep 7 13:12:34 2007 for LibMultiScale by  doxygen 1.5.2
