xml_parser_restart.cpp
Go to the documentation of this file.
00001 /* ./parser/xml_parser_restart.cpp
00002 **********************************
00003 Copyright INRIA and CEA
00004
00005 author : Guillaume ANCIAUX (anciaux@labri.fr, g.anciaux@laposte.net)
00006
00007 The LibMultiScale is a C++ parallel framework for the multiscale
00008 coupling methods dedicated to material simulations. This framework
00009 provides an API which makes it possible to program coupled simulations
00010 and integration of already existing codes.
00011
00012 This Project is done in a collaboration between INRIA Futurs Bordeaux
00013 within ScAlApplix team and CEA/DPTA Ile de France.
00014
00015 This software is governed by the CeCILL-C license under French law and
00016 abiding by the rules of distribution of free software.  You can  use,
00017 modify and/ or redistribute the software under the terms of the CeCILL-C
00018 license as circulated by CEA, CNRS and INRIA at the following URL
00019 "http://www.cecill.info".
00020
00021 As a counterpart to the access to the source code and  rights to copy,
00022 modify and redistribute granted by the license, users are provided only
00023 with a limited warranty  and the software's author,  the holder of the
00024 economic rights,  and the successive licensors  have only  limited
00025 liability.
00026
00027 In this respect, the user's attention is drawn to the risks associated
00028 with loading,  using,  modifying and/or developing or reproducing the
00029 software by the user in light of its specific status of free software,
00030 that may mean  that it is complicated to manipulate,  and  that  also
00031 therefore means  that it is reserved for developers  and  experienced
00032 professionals having in-depth computer knowledge. Users are therefore
00033 encouraged to load and test the software's suitability as regards their
00034 requirements in conditions enabling the security of their systems and/or
00035 data to be ensured and,  more generally, to use and operate it in the
00036 same conditions as regards security.
00037
00038 The fact that you are presently reading this means that you have had
00039 knowledge of the CeCILL-C license and that you accept its terms.
00040 ***********************************/
00041
00042 #define LOCAL_MODULE MOD_PARSER
00043
00044 #include "../common/common.h"
00045 #include <sstream>
00046 #include "xml_parser_restart.h"
00047
00048 bool Triplet::domainSizeIsSet;
00049 Cube Triplet::geom(3);
00050 double Triplet::tx = 0;
00051 double Triplet::ty = 0;
00052 double Triplet::tz = 0;
00053
00054
00055 inline void truncate(double * a){
00056
00057   //  print_double(*a);
00058   unsigned int * temp = (unsigned int *)a;
00059   *temp = 0;
00060   //print_double(*a);
00061 //   ++temp;
00062 //   int mask = 2047;
00063 //   mask = ~mask;
00064 //   *temp = *temp & mask;
00065
00066   //  print_double(*a);
00067 }
00068
00069
00070 void Triplet::Truncate(){
00071   //  if (!domainSizeIsSet) FATAL("Warning : domain size shloud be set to truncate coordinates");
00072
00073   // int nx = (geom.Xmax() - geom.Xmin())/1e-10;
00074   //translating
00075   x += tx;
00076   y += ty;
00077   z += tz;
00078
00079   truncate(&x);
00080   truncate(&y);
00081   truncate(&z);
00082 };
00083
00084 void Triplet::SetDomainSize(Geometrie & g){
00085   domainSizeIsSet = true;
00086   geom = GeomTools::GetBoundingBox(g);
00087 };
00088
00089
00090
00091 void XMLRestartParser::charHandler(const XML_Char * str,int len){
00092   char * buf;
00093
00094   DUMP("read a line of size " << len,DBG_ALL);
00095   if (len == 0)
00096     return;
00097
00098   buf = new char[len+1];
00099
00100   strncpy(buf,str,len);
00101
00102   if (type == TEXT)
00103     buf[len]='\0';
00104   else
00105     b64.SetStream(buf,len);
00106
00107   if (buf[0] == '\n')
00108     return;
00109
00110   //    DUMP("len = " << len);
00111   //DUMP("buf = " << buf);
00112
00113   switch (current_field){
00114   case P0S: manageP0(buf);break;
00115   case DEP: manageU(buf);break;
00116   case VEL: manageV(buf);break;
00117   case ACC: manageA(buf);break;
00118   }
00119
00120   delete [] buf;
00121 };
00122
00123
00124 void XMLRestartParser::startElement(const char *name,const char **atts){
00125   int j;
00126   cpt=0;
00127
00128   if (strcmp("SimulationData",name)==0){
00129     for (j=0; (j < 10  && atts[j] != NULL);++j){
00130       if (strcmp("dim",atts[j])==0){
00131         Dim = atoi(atts[j+1]);
00132         //printf("Dim = %d\n",data.Dim);
00133         ++j;
00134       }
00135       /*       if (strcmp("Unity",atts[j])==0){ */
00136       /*        if (strcmp("Real",atts[j+1])==0){ */
00137       /*          unit.SetReadUnits(UnitsConverter::AtomsUnits); */
00138       /*        } */
00139       /*        else if (strcmp("Atoms",atts[j+1])==0){ */
00140
00141       /*        } */
00142       /*        ++j; */
00143       /*       } */
00144       if (strcmp("dataType",atts[j])==0){
00145         if (strcmp("TEXT",atts[j+1])==0){
00146           type = TEXT;
00147         }
00148         else type = BINARY;
00149         ++j;
00150       }
00151       if (strcmp("nbDofs",atts[j])==0){
00152         nbDofs = atoi(atts[j+1]);
00153         //printf("nbNodes = %d\n",data.nbNodes);
00154         ++j;
00155         tab_indexes = new int[nbDofs];
00156       }
00157       if (strcmp("savedTime",atts[j])==0){
00158         savedTime = atoi(atts[j+1]);
00159         //printf("nbNodes = %d\n",data.nbNodes);
00160         ++j;
00161       }
00162     }
00163   }
00164   if (strcmp("P0",name)==0){
00165     current_field = P0S;
00166     DUMP("reading intial positions",DBG_INFO);
00167   }
00168   if (strcmp("U",name)==0){
00169     current_field = DEP;
00170     DUMP("reading displacements",DBG_INFO);
00171   }
00172   if (strcmp("V",name)==0){
00173     current_field = VEL;
00174     DUMP("reading velocities",DBG_INFO);
00175   }
00176   if (strcmp("A",name)==0){
00177     current_field = ACC;
00178     DUMP("reading accelerations",DBG_INFO);
00179   }
00180
00181
00182 };
00183
00184
00185 void XMLRestartParser::endElement(const char * name){
00186
00187   char message[256];
00188
00189   switch (current_field){
00190   case P0S: sprintf(message,"%s : in vector P0s ",name);break;
00191   case DEP: sprintf(message,"%s : in vector Us ",name);break;
00192   case VEL: sprintf(message,"%s : in vector Vs ",name);break;
00193   case ACC: sprintf(message,"%s : in vector As ",name);break;
00194   }
00195   current_field = NONE;
00196
00197   if (cpt != 0 && cpt != nbDofs)
00198     FATAL(message << ": values number do not concord (read " << cpt << " should be " << nbDofs << ")");
00199 };
00200
00201 int XMLRestartParser::readTriplet(Triplet & C,char * s){
00202   if (type == TEXT){
00203     std::istringstream str(s);
00204     char tmp[256];
00205     if (triplet.getRead() == 0 && str >> tmp) {
00206       triplet(0) = atof(tmp);
00207       triplet.getRead()++;
00208     }
00209     else return 0;
00210     if (triplet.getRead() == 1 && str >> tmp) {
00211       triplet(1) = atof(tmp);
00212       triplet.getRead()++;
00213     }
00214     else return 0;
00215     if (triplet.getRead() == 2 && str >> tmp) {
00216       triplet(2) = atof(tmp);
00217       triplet.getRead()++;
00218     }
00219     else return 0;
00220   }
00221
00222   if (type == BINARY){
00223     for (int i = triplet.getRead() ; i < 3 ; ++i){
00224       DUMP("read " << triplet.getRead() << " " << i,DBG_ALL);
00225       triplet.getRead() += b64.PopDoubleInBase64(triplet(i));
00226       DUMP("read " << triplet.getRead() << " " << i,DBG_ALL);
00227       if (i+1 != triplet.getRead()) {DUMP("already red " << triplet.getRead() << " components of the triplet",DBG_ALL);return 0;}
00228     }
00229   }
00230
00231   C = triplet;
00232   triplet.getRead() = 0;
00233
00234   return 1;
00235 }
00236
00237
00238 void XMLRestartParser::manageP0(char * s){
00239   Triplet C;
00240   while (readTriplet(C,s) && cpt < nbDofs){
00241     C.Truncate();
00242     mapP0[cpt] = C;
00243     DUMP(C(0) << " " << C(1) << " " << C(2) << " " << cpt,DBG_ALL);
00244     ++cpt;
00245   }
00246 };
00247
00248
00249 void XMLRestartParser::manageU(char * s){
00250   Triplet u;
00251   while (readTriplet(u,s) && cpt < nbDofs){
00252     mapU[mapP0[cpt]] = u;
00253     DUMP(u(0) << " + " << u(1) << " + " << u(2) << " + " << cpt,DBG_ALL);
00254     ++cpt;
00255   }
00256 };
00257
00258 void XMLRestartParser::manageV(char * s){
00259   Triplet v;
00260   while (readTriplet(v,s) && cpt < nbDofs){
00261     mapV[mapP0[cpt]] = v;
00262     DUMP(v(0) << " + " << v(1) << " + " << v(2) << " + " << cpt,DBG_ALL);
00263     ++cpt;
00264   }
00265 };
00266
00267 void XMLRestartParser::manageA(char * s){
00268   Triplet a;
00269   while (readTriplet(a,s) && cpt < nbDofs){
00270     mapA[mapP0[cpt]] = a;
00271     DUMP(a(0) << " + " << a(1) << " + " << a(2) << " + " << cpt,DBG_ALL);
00272     ++cpt;
00273   }
00274 };
00275
00276
00277 bool XMLRestartParser::IsDofRegistered(double x,double y, double z){
00278   double epsilon2 = .8e-10*.8e-10;
00279
00280   if (Dim < 3) z = 0;
00281   if (Dim == 1) y = 0;
00282   Triplet a(x,y,z);
00283   a.Truncate();
00284   if (mapU.count(a) == 0) {
00285     std::map<Triplet,Triplet>::iterator pos;
00286     DUMP("testing if already registered with the position " << a,DBG_ALL);
00287     pos = find_if(mapU.begin(),mapU.end(),close_enough(a));
00288
00289     if(pos != mapU.end()){
00290       Triplet found = pos->first;
00291       double dx = a(0) - found(0);
00292       double dy = a(1) - found(1);
00293       double dz = a(2) - found(2);
00294
00295       double rmin = dx*dx + dy*dy +dz*dz;
00296       DUMP("minimal distance = " << FORMATREAL(rmin) << " " << found(0) << " " << found(1) << " " << found(2),DBG_ALL);
00297       if ( rmin > epsilon2 ) return false;
00298       Triplet::tx = found(0) - x;Triplet::ty=found(1) - y;Triplet::tz=found(2) -z;
00299       DUMP("translation  " << FORMATREAL(Triplet::tx) << " " << Triplet::ty << " " << Triplet::tz,DBG_ALL);
00300
00301       return true;
00302     }
00303     DUMP("Triplet not found :  " << a,DBG_ALL);
00304     return false;
00305   }
00306   return true;
00307 };
00308
00309
00310 void  XMLRestartParser::AssignDispField(double x,double y, double z,double & ux, double & uy,double & uz){
00311   if (Dim < 3) z = 0;
00312   if (Dim == 1) y = 0;
00313   Triplet a(x,y,z);
00314   a.Truncate();
00315   Triplet &b = mapU[a];
00316   ux = b(0);
00317   uy = b(1);
00318   uz = b(2);
00319 };
00320
00321 void  XMLRestartParser::AssignVelField(double x,double y, double z,double & ux, double & uy,double & uz){
00322   if (Dim < 3) z = 0;
00323   if (Dim == 1) y = 0;
00324   Triplet a(x,y,z);
00325   a.Truncate();
00326   Triplet &b = mapV[a];
00327   ux = b(0);
00328   uy = b(1);
00329   uz = b(2);
00330 };
00331
00332 void  XMLRestartParser::AssignForceField(double x,double y, double z,double & ux, double & uy,double & uz){
00333   if (Dim < 3) z = 0;
00334   if (Dim == 1) y = 0;
00335   Triplet a(x,y,z);
00336   a.Truncate();
00337   Triplet &b = mapA[a];
00338   ux = b(0);
00339   uy = b(1);
00340   uz = b(2);
00341 };
00342
Generated on Fri Sep 7 13:12:35 2007 for LibMultiScale by  doxygen 1.5.2
